Question about Honda Air Tools & Compressors
My air compressor starts right up, runs for approximately a minute, then quits. If left sitting for a minute or two, it will start again, and run for a minute, then stop. If you shut the fuel off, it will still start up again. Does this sound electrical? Carbuerator?
  • 54 Answers
It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
Bruce
Posted on Mar 31, 2011
Snapping noise then quits
Not sure what model yours is, but sounds like you have a bad start capacitor that has dried up or swelled and "snapping" when making connection. If you can give me the Brand and model number I can see what capacitor you need.
May 12, 2014 | Dometic Rooftop RV Air Conditioner
2001ford f 250 super duty diesel air conditioner problems
Sounds like a fan clutch problem or ??
Can you drive it and when it quits cooling check and see if the compressor is still running ?
Jun 29, 2012 | 2001 Ford F250 Super Duty Super Cab
STARTS and runs well but quits and wont start again until it sits awhile.Acts like vapor lock,checked fuel and spark,compression and timing,all good.Replaced fuel filter,mass air sensor and cut holes in...
I had the same problem but when I changed the Mass Air Flow it was solved. I am suprised that you changed the MAF and you are still getting problems. Please get an OBD check. The problem must be having something to do with electronics and the ODB will definetly be able to read it.
Sep 01, 2010 | 1998 Volvo S70
UNIT RUNS FOR APPROXIMATELY 12 / 15 minutes BLOWING COLD AIR, THEN SOUNDS AS THOUGH A RELAY TRIPS IN AND IT BEGINS BLOWING COLOD ? IF LEFT FOR AN HOUR OR SO, IT WILL START TO BLOW THE COLD AIR AGAIN, BUT...
It sounds like you may have a bad capacitor or a poor connection on some wire at the compressor terminals. I assume the fan is running outside with the compressor and that the condenser is clean. *Note if it needs "regassed" (recharged) it means there is a leak somewhere that needs to fixed first. Hopefully that is not your problem.
Jun 29, 2009 | Heating & Cooling
Compressor shuts down 59516.531G
Is the compressor too hot to touch when it shuts down? This would indicate a low charge
Aug 02, 2008 | Dometic 57915531 Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Air Tools & Compressors Logo
189 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
