Question about Profile PCD920 AM/FM Flip Down CD Player
What is the orange wire for. - Profile PCD920 AM/FM Flip Down CD Player
  • 12,061 Answers
Either the power antenna wire, OR the Always ON power, to keep the memory settings alive when ignition is OFF.
Posted on Mar 31, 2011
Wiring mex bt31pw cd player to 2003 hyundai accent with no wiring adapter. Need to know what color wire go to what on the vehicle
2003 Hyundai Accent Car Radio Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Orange/Black
Car Radio Switched 12v+ Wire: Pink
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Black
Left Front Speaker Positive Wire (+): Red
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Brown
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Black/White
May 01, 2017 | Hyundai Cars & Trucks
Where is the location of the power seat circuit breaker on a 2001 s10 blazer lt?
I think that more than likely wher eit draws the power in the fuse box the circuit feed to the fuse is burnt out ,this is often a strip on the back of the fuse box that runs across the frrd to the fuses so check for a feed in the fuse box on the fuse for the power seat
Oct 21, 2014 | 2001 Chevrolet Blazer
Orange\black wire in the radio of ford
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: Orange/Black
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 18, 2012 | 1991 Ford Bronco
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
1993 dodge shadow radio wire diagram i have a problem with my instrument lights on the dash board speed,gas,temp,gages lights will not come on the radio light is on and it plays and works good but i have...
Hello! I will assume you are connecting a factory radio for your 1993 Shadow.
Remove the Orange wire from ground...Listed below is wiring from car to radio; You may need this one day...You are correct; There isn't a dimmer wire...The Orange wire, from the radio, connects to the Orange/White of the vehicle...Grounding the Orange wire is causing your problem...
1993 Shadow...Orange/ White=Illumination...Red=Hot at all times...Red/White=Switched 12volts...Black=Ground
Factory radio...Orange=Illumination...Pink=Hot at all times... Red/White=Switched 12volts...Black=Gnd.
Car; Orange/White to Orange of radio
Red To Pink
Red/White To Red/White
Black To Black
Let me know how you make out..
Guru...............saailer
Feb 04, 2010 | Car Audio & Video
Need colour codes for radio
this is what I show for Passat.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Ignition Switched 12V+ Wire: Orange
Car Stereo Illumination Wire: Gray/Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Black
Left Front Speaker Wire (-): Orange/Black
Right Front Speaker Wire (+): Red/White
Right Front Speaker Wire (-): Orange/White
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Red/Light Green
Left Rear Speaker Wire (-): Orange/Black
Right Rear Speaker Wire (+): Blue/Light Green
Right Rear Speaker Wire (-): Orange/Red
Aug 13, 2009 | 1993 Volkswagen Passat
Wiring problems?
http://inform3.kenwoodusa.com/manuals/kdcmp238.pdf
There are no illumination wires on this deck, so the Orange and orange/wht are not used on the wiring harness. Orange wire is NOT for memory. Yellow wire is +12VDC Constant for memory.
If you hooked up the 12Vdc to the orange wire, your fuse for your dashlights have blown. Check your cars fuse panel for a blown fuse.
The orange wires are sending a signal out to radios with illumination circuts. You just sent a 12VDC signal upstream and it collided with the Cars signal and blew the fuse.
Tape off the orange wires, and all will be fine after changing the fuse.
Dec 28, 2008 | Kenwood KDC-MP208 Car CD/ MP3 Player
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Profile PCD920 AM/FM Flip Down CD Player Logo
20 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
