Question about Linksys Wireless-G WRT54G Router
LimeWire I am having trouble connecting to LimeWire. I believe it is my router (Linksys - WRT54G). I have a direct connection to the router with my desktop and a wireless connection to my laptop. I may have touched the reset button a few weeks ago on the router. How do I get the router to accept me connecting to LimeWire?
    President:
  • 357 Answers
Hi
If you have recently got a new router, there would be a firewall on the router blocking the required ports for LimeWire to operate. To get around this, refer to your Router's user manual and find out how to access it and then unblock those certain ports. PLEASE NOTE: Do not attempt to unblock all the ports as this will increase the risk of getting your router and perhaps your computers infected with viruses.
If that is not your problem, you may be using and ISP (Internet Service Provider) that has blocked those ports as downloading music uses a lot of bandwidth which is a burden on them. If you have Satellite Internet, this is probably the case. You can try and resolve this by contacting your ISP and negotiating a price for them to unblock the port for you.
Please remember to give this solution a FixYa! rating.
Kind regards
BearWeb
Posted on Apr 12, 2009
  • 2,794 Answers
If the firewall is turned on you router you will have to turn off the ports that LimeWire uses.
Posted on Aug 04, 2008
SOURCE:
Linksys wireless g wrt54g router connectivity drop: our linksys wireless router disconnects about every day. We are forced to unplug the router, wait 30 seconds, and then reconnect, which brings the...
Couple actually... 1. See if you can reset the router once and set it up once again. 2. Check if you can upgrade the firmware of the router. 3. To ensure this is not a wireless issue, go wired and check if the issue continues4. Also connect to the modem directly , bypassing the router to make sure its not the modem thats actually causing the trouble.
Sep 26, 2011 | Linksys Wireless-G WRT54G Router
Have a WRT54G lately my hardwired desktop connection has been loosing it connection while my 2 laptops will stay connected with no problems.. only way hardwired connection will reconnect is to reboot...
How long have you been using the router? Might need to update the firmware on your WRT54G. But do it EXACTLY as instructed on the Linksys website, as incorrect attempt can result in need for new router. I know that sounds drastic, but you can do it just fine - just be aware that you have to follow the steps precisely as they are stated and in the correct order. Never had a problem myself, but have heard of those who did, and it was ALWAYS because they did not follow directions. If you are not comfortable doing it, get a "techie" friend to do it for you.
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Having trouble connecting to the internet
Hi, the problem you have described has many solutions..lets try
do you have any hard wired pc directly connected to your router..are you able to on line in that pc..if not connect your modem directly to your pc and check if you are online..if yes the you router configurations has to checked..and make sure your router is updted with the latest firmware..reconfig your router and that will fix your problem
Oct 19, 2009 | Linksys Wireless-G WRT54G Router
My linksys router won't allo me to connect to the internet.
Well to be honest. The reason you keep having the problem is because your router resets itself every few hours. If your routers firmware was already updated by LInskys support and the same thing happens then you will indeed need a new router. Newer models and even the one that you have are all reliable the only problem in your case is most likely wear and tear. You have had it for a few years now hence most likely its degraded to a point that it resets itself which causes your problems so yes i would suggest you get a new one. YOu can get the latest WRT54G V8
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys Wireless-G WRT54G Router Logo
160 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
