Question about Dell F3534 Touchpad
I have a Dell Studio laptop and the left click has stopped working. I can still select by tapping the touch pad, and the right click still works - but nothing happens when I push the left. Thanks!
    Sergeant:
    Champion:
  • 273 Answers
The touch pad might need to be replaced which can be a hassle and quite expensive. If you go into the touch pad settings you can switch the left and right and also make some other adjustments. Check that one of those isn't the cause of the problem.
Posted on Mar 31, 2011
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Dell touchpad tab gone from mouse settings. tried installing driver with no luck. Also tried uninstalling and reinstalling driver.
Customizing the Touch Pad
You can use the Mouse Properties window to disable the touch pad or adjust
the touch pad settings.
1 Click Start , and then click Control Panel.
2 Click Hardware and Sound.
3 Click Keyboard.
4 In the Mouse Properties window:
• Click the Device Select tab to disable the touch pad.
• Click the Touch Pad tab to adjust touch pad settings.
5 Click OK to save the settings and close the window.
Apr 06, 2010 | Dell Studio 17 Laptop
"click" feature will not work on Scrollpad of Dell Studio 1737
install the touch pad driver and the configure the seetings in control pannel
Jan 11, 2010 | Dell Studio 1737 Laptop
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
Keyboard lights not working
are you referring about the keybaord back lights? please check bios version. turn on computer then keep tapping f2 to enter bios. compare it with from the bios from he support site..if all fails then ask dell support tech to have keyboard replaced.
Oct 03, 2009 | Dell Studio 1737 Laptop
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
