Wireing schematic Im am in nedd of a schematic to put the main board back in.
Hi my name is haile
I have a Mitsubishi Big Screen TV Model BS5006R .it mix the tree light (green,blue and read ) because of this it has poor pictur qualuty and some times it is difficalt to identify some picture .
if possible please seand bord diagrame by this maile haile_ars@yahoo.com thanks.
Posted on Mar 08, 2009
My sharp has sound but no picture a have put it a zgemma box using hbmi cable got sound no picture is there something a need to press for the picture to match the box
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 22, 2016 | Sharp Televison & Video
GREEN LIGHT COMES ON THAN SHUTS OFF WS-65313
Issues where water has been splashed onto the board can cause so many weard issues, it is easyer to replace the board then try to replace the individual parts. You need to do allot of troublshooting that will requrie schematic and a good knowlage of that board. try to get your board from pts, http://www.moduslinkptstvboards.com/
Sep 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Drop my tv rip out the power cord philips tv model 20pt6341/37
hi i hope i can help you ? you said there is two bent pins on the main cicuit board can you please have a look do they say L N at the bottom of the pins? if yes this is where you reconnect. top tip where you had the tv pluged in and where the tv is normally this will give a good indication if that is where you put the L N.also please check the pins for any damage. like solder joints for safety.
May 01, 2009 | JVC AV-48WP30 48" Rear Projection...
Mitsubishi ws55513
there is a small piece of a ground strap under the DM module that the metal case has to engage
Jan 22, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mistubishi vs-45605 pip module
The PIP board is small and square and stands straight up on the main board. It plugs into a socket. It also has a ground wire that has to be unsoldered to remove it from the machine. It is located essentially in the middle of the main board near the rear of the set. Sorry I can't describe it any better. Go to http:\\www.tritronicsinc.com or call 1-800-638-3328 for parts. Thank you!!
barneyluc
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
G e t v
I have the 46GW945 set and the schematics were folded up and stuck under the main convergence board (one on the right) but the board with the chip on it should be staring you in the face as you look in the back of the unit. Another interesting thing is the chip is not a STK392-110 on my board it is a STK730-130
Aug 31, 2008 | GE 46GW945 46" Rear Projection Television
DTV not working
YOU HAVE SOME LOOSE CONNECTIONS ON THE BACK PANEL OR IN THE MAIN A/V BOARD ASSY,YOU NEED TO OPEN THE TV AND LOOK FOR THE INSIDE OF THE JACK BOARD AND THE BOTTOM OF THE MAIN A/V BOARD
GOOD LUCK
CAYPIANAN@YAHOO.COM
Jun 16, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS55513
Hello I have a wd-52825 mitsubishi 2004.. it was working fine until last week.. I did replace the lamp and now I have new problems . green light came on, then a sound like weeeeeeeeeeeeeee for maybe 2minutes . here we go .. green light go off..
Help please
Mar 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Checking electrical components--Mitsu WS 55513
hello the power supply board is to the right of the set . when you are looking at it from the back.!!! how you will know is the fly back transformer will be there, it will be black in color & will have 3 to four red wire's comming out of it.!!! there are 3 fuse on that board . !!!! they look like a regular fuse .!!! but just smaller in size.!!! they should not be hard to find.!!! you might want to get your self some glasse's to help your self see better.!!! well a"good luck" hope this help's you.!!
Mar 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Plug in tv and doesnt work
If you have no Tv repair experience, how do you know what part this is?, as I dont have a clue as you didnt supply a schematic or a picture of what the part was. We techs have a trade we learned not by doing but by going to school to learn the theroy behind the circuits. If you know how to read a schematic diagram, i suggest that you get one and know what part it is that you think you found burnt out. If you go to http://www.servicemanuals.net, download a service manual or schematic diagram, i will assist you in this repair as long as you have the proper equipment such as a mutimeter and know how to trouble shoot solid state electronics. Its not a tube you can take out and test or a board that can be exchanged anymore my freind. Its down to the componet level these days.
Sep 23, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
