Question about Whirlpool Refrigerators
Hi I just bought a whirlpool refrigerator and it rolls forward on opening the doors. Is there anyway to prevent this? It is on a wooden floor, Thank You Model NumberED5FVGXWS
  • 132 Answers
At the bottom front of the refrigerator there are two feet. One on the left and one on the right. These need to be screwed down untill they touch the floor. Once they are touching the floor they should act as anchors stopping the fridge from moving
Posted on Apr 01, 2011
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
Integrated fridge door keeps springing open. what is causing this?
the magnetic seal along the door may have gone bad. or bad worn out door seals not keeping or creating the pressure needed to cling door shut
Feb 19, 2015 | Whirlpool Refrigerators
Replacing door gasket (gasket panel)
ok if the door is opening it might be tipped forward. Try leveling the unit or tip slightly toward the back. Won't take much and you can use
anything solid and flat to prop it up.
I hope this helps.
May 20, 2013 | Whirlpool Refrigerators
How can i roll the refrigerator out to vacumm the coils?
open the freezer and when the drawer stops you can pull from the door and it should roll . make sure that a foor is not set in front to prevent roll out .. mm . different ways to get any frig out depends on the floor its on . wood is easy carpet not so easy and tile has grouves and make's it hard. so just use you head . i use nylon slides to help an carpet and to protect wood floors . some dent easly ....
Oct 14, 2010 | Amana AFD2535DES French Door Refrigerator
How do i stop a refrigerator door from swinging open too far?
It sounds as if your fridge is leaning forward and the weight opens the door to quick and to far, try to get it level and then it will only open as far as you open it.
Regards
Chris
Jan 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I need to level the refrigerator. The back needs
Hello Monty, If you can roll the fridge out, you'll likely see the adjustment screws for the rear wheels, (if equipped). If the rear wheels are fixed, as most are, you can put a couple of wooden shims down on the floor where the wheels will be and roll the fridge back into place and then make the leveling adjustments from the front wheels.
If the amount of height adjustment is greater than a half an inch, you can use a solid piece of plywood the width of the fridge and about 4-6" wide and place that at the back. Roll the fridge in until it hits the plywood and tilt the fridge forward about 2 inches and push it back until the rear wheels are on the plywood. You can then, again, level the fridge using the front wheel/leg levelers.
I've found that it's easier to get a good idea of just how much out of level the space is where the fridge is being placed. Then you can make the changes using the best materials for the situation. Shims are fine for small adjustments, while the full width plywood is more consistent and easier to adjust, as the fridge will likley get moved out every 6 months or so, for cleaning of the coils and behind the fridge.
Remember that ideally, you want the front of the fridge just slightly higher than the back, so the doors will close by themselves, when opened almost 90 degrees and released by hand. Gravity should then take over and automatically close the doors, ensuring a good seal to keep the fridge closed and running properly.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Maytag MFI2568AE Side by Side French Door...
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I know it has castors/wheels but don't know how to move it
It will roll star straight forward and straight back. Not side to side.
Nov 20, 2009 | Whirlpool ES5FHAXS Side by Side...
Old Refrigerator
Clean it with a bleach solution and leave the doors open for several days. (out in the sunshine if possible).You can try putting a bowl of plain charcoal (not the match-lite kind) and letting it run empty with only the charcoal for a week or 2. If anything got into the insulation you are out of luck. Even the plastic liner will absorb odors and become difficult if not impossible to remove.
Eric
Oct 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door makes poping sound when opened
Hi
Thanks for using FixYa. Please check the lower door hinge and the door gasket. There is a small hex screw that prevents the plastic hinge support from moving and while moving it makes a popping sound if it is loose. To resolve the issue you just need to tight it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
717 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
