Question about JVC TH-M303 System
Sub dont play when in dvd mode - JVC TH-M303 System
  • 3 Answers
It could be the setting you are in sometimes there is different settings when you are i different modes just go in and change them and you will be fine and it should work just look at the manual and follow it
Posted on Mar 31, 2011
Cda 9885, When in tuner mode sub does not play
Does you car volume get lower when you stop. If not sounds like an internal issue. No sound at all my brother hooked his up and when he switched to tuner everything would go through the subs but you would not know it sounded like his 6x9s no bass. was a wiring issue. I dont know if this helped or not.
Feb 28, 2014 | Alpine CDA-9885 CD Player
Jbl dsc 500 dvd power failing issue
Got the exact same issue... can't find a solution anywhere.
May 08, 2012 | JBL Audio Players & Recorders
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
My radio will play perfectly on turner but when inserting dvd/cd the radio only plays sound from the four internal speaker and not from the sub
try using your blue/white wire instead of the blue wire to turn your amp on. The blue wire is power antenna remote turn on and shuts off when leaving tuner mode. The blue/white wire is amplifier remote turn on.
May 20, 2011 | Jensen VM9510 Car DVD Player
How do i make my subs play when playing a video dvd they play when th radio is on
Does your subs play when you are playing a cd?If yes then you need to check the turn on lead for your sub amp and make sure your jensen deck is putting 12 volt out when your dvd is playing.If it is not you need to find the correct amp turn on wire, if it is then you may have to re equilize your sound when you are playing dvds.
Jul 30, 2010 | Jensen VM9410 Car DVD Player
Subwoofer does not kick in during stereo mode with front speakers
There should be an adjustment in setup that for 2 channel sources, you may have to enable the subwoofer output. Or alternatively, if the subwoofer output for 2 channel sources is in fact enabled, then increase the crossover frequency for the sub.
May 07, 2009 | Audio Players & Recorders
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Radio works cd/dvd does not.
What do you have your remote wire for your amplifier connected to?
Dec 05, 2007 | Panasonic CQ-VD7001U Car DVD Player
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
JVC TH-M303 System Logo
49 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
