Question about Bosch Nexxt300 WFMC220 Front Load Washer
I have an Bosch washing machine, model WFMC6400UC 12391301. I get the drain blocked Fault notice on the control panel.I have opened the cover and observed the pump working, I have blown out the discharge hose to the drain,and looked into the discharge hose from the tub to the pump and nothing is blocking them....although the waste water from the tub to the pump drains rather slowly.what do you think? Thanks Frank Rhoads
  • Bosch Master
  • 744 Answers
Bosch washing machine, model WFMC6400UC 12391301 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
  • 5 Answers
SOURCE: Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Posted on May 16, 2007
  • 3 Answers
SOURCE: have a Bosch WFMC 3200UC and gives a E04 error.
In order to unlock the door on this machine you must first turn the cycle knob to a cycle that was different than the one you were on. The machine should then reset and the door should unlock.
Posted on Jul 17, 2008
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
Mar 26, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Faulty drain pump on bosch washing machine
WFMC6400UC Front Load Washer This video will show you how to change the pump washing machine
Oct 29, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer has stopped and error says suds or blocked pump
Hi, there is a round cover on the front left corner. Install a pick in the small hole and turn the cover. You will see a twist cap behind the cover. Unscrew the cap and remove what ever is blocking the pump from turning. Watch out because the water in the tub will drain out.
That should fix the problem....
Jun 19, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch exxcel 1200 express fault code f04 what is it
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
Apr 02, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
Bosch washer - taking apart the anti-siphon valve
I have a Bosch Nexxt Washer when it goes into the spin cycle I get EOO2 and the washer stops
Mar 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch washing machine show E;04 plugged drain hose or pump
Remove cover to gain access to water pump, low rightside of front panel. Clean water pump. You should be good.
Jan 31, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Message: drainage blocked
scgawlik,
Happy to assist you,
You said,
The pipe in the back is not clogged, it is wide open. When we removed the cover for the pump in the front and open the valve, the water obviously drains out. However, when you put it back together and try to run it, it will go through a cycle and when it gets near the end of the cycle that when the message appears drainage blocked and won't drain.
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
Sep 14, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do I open the front Service Access Panel?
The round access panel turns about 5 degrees then it pulls off. If you try to pop it off you will break it. Once it's removed there is a twist on cover to gain access to the pump guts to look for crud. Unscrew the cover (put a pan under it because water will come out) and look around for anything that doesn't belong there. When you reassemble it, there is a piece on the cover that has arrows on it pointing down. Put that on the bottom and screw the cover back on.
My guess is that if your washer is full of water, it will all drain out when you disassemble the pump guts.
Jun 24, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt300 WFMC220 Front Load Washer Logo
62 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
