The problem with the unit is, it will operate normally for a while (no particular length of time is it random) then it will continually cut in and out again for different lengths of time . it will do this even with the inside controller set to off, to stop the unit we must turn it of at the isolating switch outside. after a period when turned on the cycle will start again. hope you can help thank you. Rex
  • 43,501 Answers
The unit is slightly low on refrigerant... it probably has a very small leak...
The leak will have an oil film where the refrigerant leaves the oil behind as it evaporates into the atmoshpere...
Fix the leak and recharge the unit...
heatman101
Posted on Mar 31, 2011
How do you connect wireless printer cannon 495?
You can down load as well as put in the particular drivers for the printer in the Canon UNITED STATES web site to run the particular printer wirelessly. To achieve this, you need to adhere to the particular measures down below:
1. Push the particular Upkeep key (looks just like a set of pliers and a screwdriver) about the printer frequently before the symbolic representation in which looks like "G" looks inside the LCD, then media the particular <COLOR> key help the particular wireless LAN functionality with the printer.
2. In the event the wireless LAN continues to be allowed, we all will want to down load the particular drivers in the Canon UNITED STATES web site. This website link will need you to your initial down load web site for ones PIXMA MP495:
PIXMA MP495 Individuals as well as Application web site
After about the preliminary down load web site for ones type, you need to accomplish the next:
1. Confirm that this operating system recognized inside the "OPERATING SYSTEM" drop-down menu can be appropriate, as well as if it's not, you need to click the drop-down menu to pick out your operating system.
3. Up coming, you need to go through the red-colored arrow next to the particular "DRIVERS" part as well as click the MP INDIVIDUALS file. When you accomplish, an additional web site look supplying details of the particular file you happen to be planning to down load look.
3. You should scroll lower about the Information web site as well as agree to the particular terms with the please note message to keep with the down load course of action simply by exploring the particular "I AGREE : START OFF DOWNLOAD" key. Immediately after clicking the particular "I AGREE : START OFF DOWNLOAD" key, adhere to the particular directions to down load as well as put in the particular driver. The time for the down load course of action can vary greatly according to the rate of your Internet connection as well as the length of the particular file staying down loaded. You should be sure you have the UNIVERSAL SERIES BUS cable tv unplugged in the laptop or computer prior to installing the particular drivers; the particular setting up plan can induce you to select that within at the appropriate time.
In the event the drivers are usually down loaded as well as mounted, you need to reboot your personal computer, and you should be ready for success to print.
Canon PIXMA MX495 Driver Download Review Install
May 05, 2014 | Canon PIXMA MP160 All-In-One InkJet...
I have galexy tab 3 7.0 SM_T210R when it's on standby mode charging normally but when i turn it off it doesn't charging anymore what's the problem??
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Apr 01, 2014 | Samsung Galaxy Tab 3 7.0" - White...
Plays discs at random. Error code 90. Not accepting bills.
I discovered a "continuous play" switch on one of these jukes. it's not in the manual AT ALL!! It is located in the lower right hand corner of the cabinet to the right of the selection computer (see Pic) I didn't even see it at first. The position in the pic is set to play all the time Randomly! The down position is normal operation.
Mar 01, 2014 | Wurlitzer Jukebox CD Player
For my Kenmore Coldspot refrigerator (106.565364), is it absolutely necessary to have that big coiled-up water line in the back? I would just as soon cut out the extra length and connect the ends with a...
Sears probably supplied the maximum length that might be needed
and assumed the user would cut it to the length needed for a particular installation
Sep 26, 2013 | Refrigerators
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
Tried to record on a DVD-R disc, but unit said that the disc was full. I then tried to finalize the disc, but the unit got stuck in the finalization process. I unplugged/replugged the unit to make it...
The most likely reason the unit got 'stuck during finalisation' is probably because there was insufficent space left on the disc for it to write the respective lead-out/menu data (or perhaps there was a bad disc sector) - disc full? Because you unplugged the unit from power point before it had finished, the disc is possibly corrupted now. Throw that disc out.
The manual clearly warns: Do not disconnect the AC power supply cord while finalising. This
can render the disc unusable.
In other words, you have lost that particular recording and you are wasting your time with that disc.
There is nothing in the manual to suggest the length of time required for DVD-R recovery - there is a recovery process for the whole unit (such as after a power cut while recording a timer program for example) but not for discs. I may be wrong here...
However, the upshot is you have lost a disc, not a recorder. Another drink coaster for your living room.
Mar 29, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I'm using a Bosch Axxis dryer for the first time. The dryer seems to run for a minute, cut out for a minute, run again, cut out again etc. Is this normal? I'm renting this place for a month and there are...
Werlcome to FixYa.
That is indeed perfectly normal. It is actually changing direction each time it stops and starts. That`s how those particular Bosch operate.
On another note, if you operate the unit on the "auto dry" cycles without enough items or extremely light weight materials in it, the dryer will stop since it cannot "sense" the garments.
Otherwise it`s all good !
Good luck.
Thank you for choosing FixYa today. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Aug 27, 2010 | Dryers
2004 yukon horn problem
obviously there is a short in the system probably in the wiring and likely it is exposed wiring. Motion,moisture, and heat would then effect the wiring and cause it too short out at different times and for varied lengths of times. driving your car would cause it to get hot under the hood, so after awhile the wiring shorts and your horn honks. Turning on and off the system causes motion and if it is stuck in a particular position when it shorts than the horn continues to honk
Jan 11, 2009 | 1999 GMC Sierra
Fluctuation in temp gauge
could be clogs. is the water pump operating correctly? does the fan operate correctly?
the temp gauge also has a sending / measuring unit. has that been checked / changed?
Sep 22, 2008 | 2004 Isuzu Rodeo
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
