Question about Dryers
I have solar lights model 555-208. The solar panel is bad.how do i get new one?
How do i operate smart solar lights?
Place the solar panel in a sunny spot to charge the batteries. If the lights do not come on at night, the panel's light sensor may be seeing other light sources and needs to be moved. The light sensor looks like a small white circle with a wavy line across it. They are usually visible and located in the solar panel. Make sure it is in the dark at night, or it will not come on. You can cover the light sensor to test that the lights are working.
Jul 08, 2014 | Smart Solar Solar String Lights 20 LEDs...
Unit does not light up
Check the input voltage terminals for power from your array. if there is no power at the input terminals, remove the wires from the controller and check for voltage again on the input wires. If there is still nothing, trace them back and keep checking each connection all the way to the panels. May be a bad connection or wiring. If you have input to the controller, it is being grounded for some reason or the circuit is open. Look for a fuse or reset on the controller. The controller its self may be bad.
Dec 22, 2013 | Morningstar ProStar PS-15M-48V, 15 Amp 48...
Having trouble with Solar charge control. Prostar.30. no light on and appears not to be charging batteries, light has flickered on and off twice, have checked the solar panel, Batteries are holding at...
That's an issue with the inexpensive charge controllers that is known. The internal voltage regulator and pulse width modulator isn't performing correctly and interpreting the power from the panel. I recommend you look at getting an AIMS Power charge controller. Their 30A model is flawless.
Apr 16, 2013 | Morningstar ProStar Charge Controller,...
Outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
May 21, 2008 | Coleman Mach 15 Air Conditioner
Dryers Logo
209 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
