Question about ESP LTD Deluxe EC-1000 Electric Guitar, Traditional Black
The back covers on my ESP EC-1000 are stuck in their position. The screws have been taken out but the plate won't budge. I need to change the 9v battery, how do I remove the cover?
    President:
  • 1,137 Answers
Try running a sewing needle around the edge of the covers to break the seal first. Careful use of an exacto knife works best.
Posted on Jul 25, 2013
  • ESP Master
  • 5,603 Answers
Probably stuck to the varnish... carefully pry upward.
Posted on Mar 31, 2011
Keyboard AC Adapter
If thje voltage is the same, the current rating is fine at 1000-1400 mA. The accessory will use the amount of current it needs and the fact that there is more "available" does not mean it will use it. The higher current rating will not ruin the equipment. Just make sure the voltage rating is the same. Cheers!
Mar 09, 2014 | Casio AD5 Keyboard AC Adapter
Esp ec 256 ltd
whats the questions???
Jan 12, 2014 | ESP Music
How do you fix a stuck foot switch on a Digitech RP350 guitar processor?
You might want to take it apart and clean it. My bass player had problems like that and I took it apart to see if I could find out what was wrong, It looked like a mouse was living in there. Its amazing how much crap builds up in those things. Just pay close attention to what you take off so you dont have problems assembling it back together. Maybe even take pictures if your electronically challenged like me. otherwise the botton might be shot, hopefully not. good luck to ya, I hope I helped. peace!
Mar 19, 2013 | Music
We need to change battery
The battery should be located in the control cavity of the guitar. It is in the back of the bass. Usually 4 screws holding it on. Inside your 9v battery will be located. Good luck
Feb 22, 2013 | ESP LTD Surveyor-414 Electric Bass Guitar
My RV600 Reverb Machine won't turn on. I'm using a standard 9v adapter...Do I need the behringer one of is my pedal just broken? I bought it about and hour ago.
Did you check the polarity of the adapter? The effect box uses inner pin for negative and outer barrel is positive which is oppsite from most consumer electronics.
Jun 22, 2011 | Behringer Rv600 Reverb Machine Effects...
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
Apr 24, 2011 | ESP Ec 1000 Ltd Deluxe Electric Guitar In...
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
I'm think about buying an alexi 200 guitar, but i want to replace the esp pick up for an emg 81. Is there a place for the battery the pickup will require?
There should be enough room inside for the battery. If there isn't you could do some routing to the body to make it fit. I personally don't have this guitar but more than likely you can position the 9v battery to fit. To keep it from moving around, you can put a piece of sponge in the cavity.
Jun 09, 2009 | ESP Ltd Alexi 200 Electric Guitar
ESP LTD Deluxe EC-1000 Electric Guitar, Traditional Black Logo
219 people viewed this question
Top ESP Music Experts
Joseph Hoffmann
rhodesworks
Are you an ESP Music Expert? Answer questions, earn points and help others
