Question about Samsung ES30 Digital Camera
Hi, I seem to have thrown out the instruction manual to my ES30 camera. I need to know how to recharge the batteries using the camera itself. Would be grateful if you can advise me. Thanks mandy
  • 17,970 Answers
Tips - SAMSUNG ES30 Batteries Care Instructions:
1. Your new battery comes in a discharged condition and must be charged before use (refer to your computer manual for charging instructions). Upon initial use (or after a prolonged storage period) the battery may require three to four charge/discharge cycles before achieving maximum capacity.
2. When charging the battery for the first time your computer may indicate that charging is complete after just 10 or 15 minutes. This is a normal phenomenon with rechargeable batteries. Simply remove the battery from the computer and repeat the charging procedure.
3. It is important to condition (fully discharge and then fully charge) the battery every two to three weeks. Failure to do so may significantly shorten the battery's life (this does not apply to Li-Ion batteries, which do not require conditioning). To discharge, simply run your device under the battery's power until it shuts down or until you get a low battery warning. Then recharge the battery as instructed in your user's manual.
4. If the battery will not be in use for a month or longer, it is recommended that it be removed from the device and stored in a cool, dry, clean place.
5. It is normal for a battery to become warm during charging and discharging.
6. The milliamp-hour (mAH) rating of the eBatts.com battery will often be higher than the one on your original battery. A higher mAH rating is indicative of a longer lasting (higher capacity) battery and will not cause any incompatibilities. An eBatts.com battery will, in most cases, outperform the original by 30% to 50%.
7. Actual battery run-time depends upon the power demands made by the equipment. In the case of notebook computers, the use of the monitor, the hard drive and other peripherals results in an additional drain upon the battery, effectively reducing the battery's run-time. The total run-time of the battery is also heavily dependent upon the design of the equipment. To ensure maximum performance of the battery, optimize your computer's power management features. Refer to your computer manual for further instructions.
The User Manual can download in the next link: ES30_English.pdf
Hope helps (remember to rate this answer).
Posted on Mar 31, 2011
    Master:
  • 340 Answers
Not every type of camera can charge the battery buy the camera itself. It seems you need a charger for the batteries
WHICH BATTERY DOES SUPPORTS IN THE SAMSUNG ES30 Will ENVI NI-CD battery work ?
You can use that battery. IT wont last as long as the alk or the Nimh
Aug 01, 2014 | Samsung ES30 Digital Camera
My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
Apr 02, 2012 | Samsung ES30 Digital Camera
NO INSTRUCTION FOR ES30 SAMSUNG DIGITAL CAMERA
Welcome to Fixya.
Hello Jean,
You can download the instruction manual of Samsung ES30 digital camera from this link http://downloadcenter.samsung.com/content/UM/201009/20100927145807546/ES30_English.pdf
The manual is in PDF format and it usually opens in an acrobat reader.
Thank you for using Fixya. Have a great day.
Jun 29, 2011 | Cameras
Hi, my Samsung ES30 has frozen with the optical zoom halfway out. The battery died as i was turning it off to charge and now will not power on.
Hay mate, I had the same problem and called the warranty butlater discovered that the battery was the issue (I used Kodak batteries but thecamera needs to have either alkaline batteries or Ni-MH batteries) Once Ireplaced the batteries of my replacement camera, problem solved.
Hope this will help...
Cheers
Don
Feb 22, 2011 | Samsung ES30 Digital Camera
Hi i have sony h7 and wan to reset to factory
Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jun 26, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Need the battery recharger and computer connector
You can find and compare your camera accessories in HERE.
Hope this helps.
Let me know for any instructions
Nov 23, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
I can't take a picture with the camera. What's wrong?
The batteries may be low. If you see the low battery icon, recharge or replace the batteries or use the optional AC adapter. The flash may be recharging. Wait until the status light turns green, and try again. The camera may be full. Check the picture counter on the display panel. Erase some pictures, or transfer the pictures to your computer and then erase them. Make sure your CompactFlash memory card is installed. You may need to format your CompactFlash memory card. Check to see if a message is displayed on the camera's LCD screen. The camera may be connected to your computer. When it's connected, you can't use any of the controls on the camera itself. See your user's manual for instructions on taking pictures from your computer.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Drained Batteries
I use professional $70k cameras for work and it's the same type of thing. If you're not using it, take the batteries out. With my A75 I have some energizer 2200mpa rechargeable AA's and the seem to last about a month or so. If I happen to be "cranking" through pictures though (upwards of 300-500) in one sitting, it will suck them dry. The rechargeable batteries last longer than the Alkalines. I was heistant with the rechargeables but for $20 I picked up a 15 minute charger and the 2200mpa AA's, now I recommend them to everyone with a digital camera. Digital cameras eat Alkaline batteries in a hurry.
Aug 31, 2005 | Canon PowerShot A75 Digital Camera
Samsung ES30 Digital Camera Logo
237 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
