Question about Desa International Reddy Heater® RHERH125AT
Photo eye stays at 5 volts dc unless I shine a flash light into it the flame looks great but only drops it down to 4.5 volts. I tryed re-aling it but no luck.
  • 232 Answers
The test- per DESA
Posted on Mar 31, 2011
Dusk to Dawn Light Adapter
Might work. Might not. Depending if the eye can sense light and dark from that position. If area is shaded, then the sensor might think it's dark earlier in evening. If the area is dark, then sensor will not do as well, or might stay ON full time.
If the outdoor light shines on nearby surface, the reflected light might cause photo eye to blink on-off throughout night.. or not function as expected.
You can add separate photo eye to any light, and choose location for photo eye.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Add a comment and say what you discover, or for followup wiring question.
Jun 10, 2013 | Home
Lights flash then powers down.
Before read this, keep in mind that this is not your model and parts are not the same. This is just to let you know the steps to take. Sorry don't have the schematic for your set, but maybe this will help in checking. I'm Ex-Army myself and Veteran of OIF and OEF.::::1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Aug 25, 2007 | RCA HD50LPW175 50" HDTV
Lights for 480v photo cell control, the blue one, come on and stay on, any suggestions, or reasons this would happen? Is longer than 5 minutes
Unknown if this is new installation, or old installation that went bad.
Old install, then check voltage is correct for rating plate, check that line power is not under-voltage, check that photo control receives enough light by shining 120Volt light bulb onto photo eye, replace photo eye
New install, check wiring. Photo cell has 3 wires, For example Black White and Red.
Black and White connect to power source, and Red goes to load.
May 01, 2012 | Hardware & Accessories
I get a 5 flash on the led code light
I forget what that code is...theres a sticker in the blower compartment or in your manual will tell you what 5 blinks means....typically its a flame signal error code....The flame sensor should be cleaned annually anyway to eliminate this problem...4 inches long and resembles a straight coathanger....clean/shine it up with emery cloth
Oct 24, 2009 | Goodman GDS80904BNA Open Flame Heater
Flashing yellow
Good Day, davidsonkens;
Try the lamp first; to check try this:
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010. Good Luck, big IRISH. back.gif
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Correct voltage for lamp connection?
(Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 .
Oct 06, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Desa International Reddy Heater® RHERH125AT Logo
21 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
