Question about Emerson EWL20D6 Television
TV POWERS UP THEN AFTER 20 - 30 SECONDS IT SHUTS OFF
  • Emerson Master
  • 5,138 Answers
Have you checked the power supply board for bad capacitors? they will be vented or puffed up on top, 1000uf 16v 2200uf 10v 3300uf 10v
Posted on Mar 31, 2011
Tv powers up. then shuts off by itself after 15 seconds. then restarts by itself...then shuts off after 15 seconds...etc...etc
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 08, 2016 | Samsung 50 in. Plasma TV
Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
Feb 14, 2011 | Samsung HL-T5676S Television
5730 powers up then shuts off seconds later, checked fuse its not blown
Nov 25, 2009 | Yamaha HTR-5730 Receiver
Tv shuts off after 2 seconds
This is made by LG / Zenith. They have had alot of problems with there TV's.It most likely has an inverter board going bad or could be power supply board. It will cost to much to repair. Get an extended warranty when you buy a new one. It will pay for itself.
Aug 02, 2009 | Vizio VA26L 26 in. LCD HDTV
TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Jul 24, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
TV turns on than shuts off right away
Try blowing the dust off mother board. Remove back. Unplug first. Then post problem again
Apr 09, 2009 | Televison & Video
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Rainbow screen then powers off
The degausser cricuit may be the fault. The degausser coil may be staying on, and thus forces a shut-down. It is also possible to have a power supply fault that can cause a similair effect.
The set will need shop service.
Jerry G.
Jul 22, 2008 | RCA TruFlat 27F520T 27" TV
Sylvania SSL2006 lcd tv
Did anyone figure out a solution or did you get rid of the TV?
Feb 19, 2008 | Televison & Video
Emerson EWL20D6 Television Logo
49 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
