Question about Refrigerators
Westinghouse model RB 421 S-L Serial No 80843355 Icing up top back left hand side frig at 2 copper pipes above Left hand end of horizontal drain tray. Right hand side vertical 8mm pipe is the one icing up over several days. Clears after defrosting, reappears within 48 hrs. Please advise cause - Solution
  • 1 more comment
  • vince_dever Aug 05, 2008
    Thank you, will give this a try, but would like another opinion.
    Thank you would like another opinion. The pipe that is icing up is inside the frig at the back left hand side .above the horizontal water drain trough.
    Thank you.
    Scholar:
  • 133 Answers
U need to go witha professnol repaier
Posted on Aug 05, 2008
  • 75 Answers
According to ur problem i think the oil has got pumped from the compressor which causes cooling at the top. to solve this problem the things to do is first switch off the refrigerator and then using the heater heat the back side of the fridge near the tubes from top to bottom then after some time u swich on the refrigerator then u can find ur fridge working correctly if again the problem comes then the lead valve is not working properly change the lead valve of the compressor if the problem persists in ur fridge
    Genius:
  • 3,422 Answers
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, i recommend you contact a qualified appliance repair technician.
  • Posted on Aug 04, 2008
    Want to get information on fan with serial # 208 KL? It is a large teal fan with 2 sets of fan blades one facing forward on the bottom and one facing the rear on top.
    your best bet is to go directly to Westinghouse, the divison should be marked in the id tag on the fan along with model number.
    remember, you need the model, not serial number, but having both on hand when calling is useful.
    Apr 03, 2016 | Westinghouse Dryers
    I have a westinghouse side by side frig about 10 years old. Model number RS695V Serial number 34700050.The problem is water is leaking out of bottom of freezer door. I believe it is caused by a clogged...
    The hose that goes to the water dispenser most likely has a crack in it somewhere inside the door. Usually the heat from the light in the door deteroriates the hose and lets water leak inside the door every time the dispenser is used.
    Feb 19, 2015 | Westinghouse Refrigerators
    My fridge is not cold
    Hello friend, I appreciate your post!
    I understand that your Frigidaire refrigerator is not working and you need it to work in cold weather. May I ask where the refrigerator is located? Additionally, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response to better assist you. -Matt
    Aug 25, 2014 | Frigidaire Refrigerators
    Grand theft auto cheat codes
    Invincibility
    While playing the game, quickly press Right, A, Right, Left, Right, RB, Right, Left, A, Y to be invincible for five minutes. You must enter the code again after five minutes to reactive invincibility. Note: This code does not make vehicles invincible.
    Full health and armor
    While playing the game, quickly press B, LB, Y, RT, A, X, B, Right, X, LB(3).
    Give weapons and extra ammo
    While playing the game, quickly press Y, RT, Left, LB, A, Right, Y, Down, X, LB(3) to get extra ammunition and the assault rifle, grenade, knife, pistol, RPG, sawed off shotgun, SMG, and sniper rifle.
    Lower wanted level
    While playing the game, quickly press RB(2), B, RT, Right, Left, Right, Left, Right, Left.
    Raise wanted level
    While playing the game, quickly press RB(2), B, RT, Left, Right, Left, Right, Left, Right.
    Recharge special ability
    While playing the game, quickly press A(2), X, RB, LB, A, Right, Left, A.
    Super jump
    While playing the game, quickly press Left(2), Y(2), Right(2), Left, Right, X, RB, RT. Hold X to jump very high.
    Faster run
    While playing the game, quickly press Y, Left, Right(2), LT, LB, X.
    Faster swim
    While playing the game, quickly press Left(2), LB, Right(2), RT, Left, LT, Right.
    Flaming bullets
    While playing the game, quickly press LB, RB, X, RB, Left, RT, RB, Left, X, Right, LB(2).
    Explosive bullets
    While playing the game, quickly press Right, X, A, Left, RB, RT, Left, Right(2), LB(3).
    Explosive melee attacks
    While playing the game, quickly press Right, Left, A, Y, RB, B(3), LT.
    Slow-motion aim
    While playing the game, quickly press X, LT, RB, Y, Left, X, LT, Right, A. The code can be entered up to three times to increase its effect. Enter it a fourth time to disable the code.
    Moon gravity
    While playing the game, quickly press Left(2), LB, RB, LB, Right, Left, LB, Left. Enter a vehicle after enabling this code to experience less gravity. Press B after jumping to float.
    Slidey cars
    While playing the game, quickly press Y, RB(2), Left, RB, LB, RT, LB.
    Spawn BMX bike
    While playing the game, quickly press Left(2), Right(2), Left, Right, X, B, Y, RB, RT.
    Spawn Buzzard (small attack helicopter)
    While playing the game, quickly press B(2), LB, B(3), LB, LT, RB, Y, B, Y. The Buzzard is a helicopter with missiles and guns. It must be spawned in a large enough area for it to appear, or it will not spawn.
    Spawn Caddy (golf cart)
    While playing the game, quickly press B, LB, Left, RB, LT, A, RB, LB, B, A.
    Spawn Comet (two door sports car)
    While playing the game, quickly press RB, B, RT, Right, LB, LT, A(2), X, RB.
    Spawn Duster (crop duster plane)
    While playing the game, quickly press Right, Left, RB(3), Left, Y(2), A, B, LB(2).
    Spawn Limo (limousine)
    While playing the game, quickly press RT, Right, LT, Left(2), RB, LB, B, Right.
    Spawn parachute
    While playing the game, quickly press Left, Right, LB, LT, RB, RT(2), Left(2), Right, LB.
    Spawn PCJ-600 motorcycle
    While playing the game, quickly press RB, Right, Left, Right, RT, Left, Right, X, Right, LT, LB(2).
    Spawn Rapid GT (two door sports car)
    While playing the game, quickly press RT, LB, B, Right, LB, RB, Right, Left, B, RT.
    Spawn Sanchez (dual-sport dirt bike)
    While playing the game, quickly press B, A, LB, B(2), LB, B, RB, RT, LT, LB(2).
    Spawn Stunt Plane (fixed-wing stunt plane)
    While playing the game, quickly press B, Right, LB, LT, Left, RB, LB(2), Left(2), A, Y.
    Spawn Trashmaster (garbage truck)
    While playing the game, quickly press B, RB, B, RB, Left(2), RB, LB, B, Right.
    Skyfall
    While playing the game, quickly press LB, LT, RB, RT, Left, Right, Left, Right, LB, LT, RB, RT, Left, Right, Left, Right. This cheat code spawns you in the air for a skydive free fall. If you hold the Analog-stick, you can glide for a long time. However, it does not allow you to use the parachute. Thus, you will usually die at the end of the free fall. It is possible to survive, but you will have very little health remaining. The best way to survive is to do a direct vertical faceplant. If you can survive the fall, this cheat is very useful for fast traveling around the map.
    Drunk mode
    While playing the game, quickly press Y, Right(2), Left, Right, X, B, Left.
    Slow-motion mode
    While playing the game, quickly press Y, Left, Right(2), X, RT, RB. The code can be entered up to four times to increase its effect. Enter it a fifth time to disable the code.
    Change weather
    While playing the game, quickly press RT, A, LB(2), LT(3), X. Each time the code is entered, it rotates through sunny, clear, cloudy, smoggy, overcast, rainy, thundering, clearing, and snowing weather.
    Feb 19, 2014 | Microsoft Xbox 360 Console
    GE Frig model TFX20JRBK ww with icing on freezer
    I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
    Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Freezer not working
    Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
    This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
    We offer free help and assistance also.
    http://servicepartstec.blogspot.com/
    Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
    Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
    This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
    Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
    You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
    To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
    Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
    Freezer is icing up on back wall and not keeping food frozen
    what is the model i beleave the techincan did not change the defrost thermostart
    Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Quit, but has power 106.56563400
    is the compressor hot? if yes, unplug , let it cool, and replace relay assy.
    Oct 13, 2008 | Kenmore 53642 / 53644 Side by Side...
    Entering cheat odes
    Cheat CodesUnlock All Levels:
    From the Mission Select screen, enter code: Y, RB, Y, RB, X
    Full Health:
    Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: LB(2), RB, X, RB, Y
    Unlimited Ammo:
    Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: RB(2), LB, X, LB, Y
    Scott Mitchell Invincibility:
    Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: Y(2), X, RB, X, LB
    Team Invincibility:
    Pause the game, hold down the Back button, Left Trigger, and Right Trigger and enter code: X(2), Y, RB, Y, LB
    Nov 29, 2007 | Microsoft Xbox 360 Console
    Refrigerators Logo
    139 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
