Question about Frigidaire FAP094P1 Portable Air Conditioner
My ac isn't cooling down like it use to and usually water comes out from the tube in the back now it doesn't can u tell me what's wrong with it
  • Frigidaire Master
  • 43,501 Answers
The unit probably has a refrigerant leak and is no longer working correctly...
heatman101
Posted on Mar 31, 2011
Cooling Fan Not Working
if the fan is electric, the problem is probably the fan thermostat. usually fitted into the water pipes near the radiator.
May 06, 2013 | 1996 Ford Escort 4 Door
Water from ac leaking inside on floor, drain tube open
Pull the fan and blower out of the enclosure and make sure the drain is really open, i will bet it isn't and has leaves blocking it on the inside.
Sep 07, 2012 | Dodge Cars & Trucks
Temperature gage goes up and down
The breather hose should run to the air cleaner housing or intake tube.
Check your radiator cooling fan. If it isn't working the car will run hot at slow speeds or idle then cool down after you get going faster. A quick check would be to turn the AC on and see if the fan comes on. If not try lightly tapping on the cooling fan motor with a wooden broom handle. If it comes on then you have a bad motor.
If the fan comes on with the AC then check to see if the fan comes on after the engine gets hot. If the engine temp doesn't kick it on then the temperature sensor might be bad.
If the fan is ok please post more info on your problem
May 27, 2012 | 2002 Ford ZX2
Engine Cooling problem 2000 Jeep Cherokee 4 cyl
Although the 4 cylinder is too underpowered to have air conditioning in my opinion, it still shouldn't overheat within 10 minutes unless something is wrong. If your Jeep doesn' not overheat when you are driving WITHOUT AC on then your compressor might have a problem and causing the engine to work too hard to turn it.
But if it overheats without the AC on, then the first thing you need to do is check the cooling fan and see if it operates! There has been a lot of problems with the cooling fan relay on this model. If that isn't it, then move to changing the thermostat and checking the water pump.
Jul 03, 2011 | 2000 Jeep Cherokee
My 1997 chevy cavalier keeps going to hot when im just sitting there and cools down wen i go and the fan to the ac aint coming on i just want to know what is wrong
When the AC fan doesn't come on, does the AC come on? Does your regular fan come on? Sprasy down your radiator when the coolant gets jotto see if the temp goes down. You have several places to look for overheatring.
Jun 06, 2011 | Chevrolet Cavalier Cars & Trucks
I have an 1999 chrysler 300m an it has an overheating problem. There is also water all over the driver side floor (front n back) it is soaked. It takes about 25mins b4 it starts smoking. Can som1 plz help...
Typically if your leaking coolant inside the car, it indicates your heater core is split and leaking. Replacing the heater core is quite the job. It requires removal of the dash board and heater box. i replaced one in a 97 Cirrus at work last week and it was a 6 hour job. If your not mechanically inclined i would definitley recomend phoneing around for quotes to local auto repair shops and getting it done profesionally.
Mar 15, 2011 | 1999 Chrysler 300M
2004 Gmc Envoy Airconditioner Condensation Is Leaking Into The Floorboard On The Passinger Side Of My Car
Most probably your condensate drain is blocked. Check to see if the usual dripping at the left front tire is continuing or not (after running the A/C and the vehicle is stopped). If not you have a choked drain pipe. The drain hose is located to the left of the engine compartment just below the AC lines coming out of the firewall. There is a rubber tube about 1" diameter and it has a small plastic tube 3/8" coming out from the bottom side of the larger tube. Please take care accessing the tube as there are pipes and tubes really hot in the vicinity. It is always a good idea to wait till the engine has cooled down. The drain tube sometimes gets blocked and causes leaking onto the rug area inside the truck, just pull the small tube out by pulling it down and clean the small/large tube. If there is any water from the AC it will drain out.
Jul 06, 2010 | 2004 GMC Envoy
Water is pouring into front floorboard when AC is turned on.
You most likely have a plugged evaporator drain hose. This small hose drains off the mosture that condenses on the evaporator core when the a/c is on. If the drain is plugged this water will ultimately find it's way out of the housing and onto the floor. Usually this little hose gets plugged with dirt, dust or other crud that accumulates over time which can be blown out to clear it. This hose is usually located down low on the engine side of firewall directly ahead of the passenger side. Most of them are only 2 to 4 inches long and about 3/8" diameter and can be kind of hard to locate.
Jun 09, 2010 | 2007 Dodge Caliber SXT Sport Hatchback
Does the unit suppose to retain the water?
No. The unit is not supposed to retain water. By product of a/c or
refridgeration is water due to air being cooled below dew point of air.
(Check your uninsulated cold water pipes on a hot, humid day. They
are usually sweating.) The tubing should be routed to drain or outdoors.
Jul 24, 2009 | GE APH10AA Air Conditioner
Honda acac sometimes blows some kind of dew air throught he vents
u most likely have some condensation building up in evap box ,,need to clean it out before it gets worse,,,if u are running it on low blower ,it is going to put out mist sometimes (if the air is really cold) because of the expansion valve pulling down the tempurature
Jul 06, 2009 | 1996 Honda Accord
Frigidaire FAP094P1 Portable Air Conditioner Logo
79 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
