Question about HP OfficeJet 7410 All-In-One InkJet Printer
Removal of ink catridges
Catridges don't seem to want to come out of the chutes
what gives?
Turn on printer
Posted on Aug 06, 2008
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
I ran out of ink in my HP Photosmart C6280 printer. I installed and the printer will work if you use the kep pad, but it will not work from the computer still thinks the two inks are empty. I've restarted,...
ok,i don know whether what im giving is a solution,but if u run out of ink,one temporary solution is to use a hair drier on the catridge,it will declog any ink that is left...It should work for 20 to 30 pages more until u finally have to replace the catridge
Jul 26, 2009 | HP Computers & Internet
Hp designjet 500 (42'')
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Jun 16, 2009 | Office Equipment & Supplies
CANNOT FIT IN THE REMOVED INK CATRIDGES INSIDE CATRIDGE HOLDER
I located a printer repair service prson locally who fixed the problem, taking printer to his service centre.Now it's OK.
May 05, 2009 | Office Equipment & Supplies
Canon MP730 Print Head needs a manual clean
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........... You can do the same procedure i don think there is a need of a separate cleaner for that......... Thanku
Jan 20, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My Printer
Basically you lift the top lid and the ink cartridges will move into place to be removed.then press down gently the lift up to remove the catridge when replacing do the reversal of removal.hope this helps?
Jan 18, 2009 | Canon PIXMA MP470 All-in-One Printer
Ink cartridge
The message seems to be saying that you have two black cartridges installed and therefore one of the colors is missing. Is that possible?
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
