Question about Yard Machines Cultivator
Two fule line where do thay go on the carb - Yard Machines Cultivator
  • oregonbob
    oregonbob Jun 11, 2012
    I had trouble determining which line was fuel and which was the return to tank (yellow). I discovered that the fuel line plugs into the connector on the bottom of my Mantis tiller M22 and the yellow return goes up next to the bulb near top of carburetor. After I figured that out it starts and runs perfect. My old fuel filter had completely corroded and melted in the tank. I had to clean entire tank of debris.
    Novelist:
  • 111 Answers
The fuel line that has the fuel filter on it goes on the side of the carburetor, it is the inlet for the fuel. The fuel line that goes back into the tank and has nothing else on it goes onto the carburetor closest to the primer bulb. All else fails, you can pump the primer and see if the fuel goes out or in by putting your finger over the inlet lines on the carburetor. If the primer bulb goes flat but does not inflate back up then that is the fuel inlet. Alternately, if the primer bulb will not go flat without air going by your finger then that is the fuel return that goes back into the tank without the fuel filter.
Posted on Mar 31, 2011
Replace fule line on ryobi wipper snipper I
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers,any comments welcome,thank you. ``
Feb 03, 2012 | Ryobi Garden
I need a diagram for a chevy 4x4 1986 front hub assembly where can i get this?
hmm..I don't think the first answer is correct I have an 86 suburban 350 and the filter is on the front of the carb under the air cleaner just as the fule line goes into the carb. there is about a 3/4 inch nut to open the fule line and the filter is inside.
Feb 23, 2011 | 1983 Chevrolet Silverado
I have a 6.5 hp briggs and stratton quantum pressure washer and it was working fine two months ago. Yesterday, I tried to start it and it would not start. I replaced the spark plug and air filter. If I...
its not getting any fule to carb strip down all fule lines and any fule taps to check there clean and fule flows freely then strip carb and clean out all jets,,,dont go poking wire into the jets it could distroy them use compressed air or card cleaner on jets
Mar 28, 2010 | Garden
I have a electric generator with a 5 horse briggs engine it was hard to start and ran with full choke. I ordered a rebuilt kit # 495606 and installed. The only way the engine will run , is to pour gas...
it has a blocked fule line and maybe blocked jets in the carb first clean all the fule lines from the tank down check the filter in the tank as well they do get rust in them, if fule is reaching the carb strip carb and clean all jets,, dont go poking wire into the jets it could distroy them check that the flote is free and lifting then clean the air filter and try starting it up,,,it should run ok then
Mar 13, 2010 | Electrical Supplies
No fuel to the plug. only starts with starter fluid n runs for a second. dry plug
start by cleaning all the fule lines and pipes out look at the fule tap in the tank it may have a blocked filter on it,then blow trough all the lines right back into the fule tank if fule is reaching the card strip the carb and clean out all the jets plus the flote bowl your bike is not getting any fule
Jan 19, 2010 | 1992 Suzuki DR 350 S
When i prime the bulb try to start it will run for abot 2 seconds and will not run.you pull and pull and it will not start.we have cleaned the carb and gas lines.the saw is just one year old.i bought it at...
Inspect your hose routing. it should be similar to this:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed. HTH
Lou
Nov 12, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The engine will not run unless you pour gas in the carb. It ran before i charged the fuel line which was rotted off. It is 2 cycle blower vacuum and i do not have the model nomber handy
its that new fule line you put in,,,its not letting any fule down to the carb you have proved there is nothing wrong with the engine, by tipping fule into the carb,,,,
have another go at fitting the new fule line,,, rember to put on the fule filter on the end that gos inside the fule tank if its not on it the pipe will not lay in the fule tank right and wont pick up any fule out the tank,,,
i bet thats were you went wrong?
Nov 10, 2009 | Craftsman 4 Cycle Blower/Vac
Toro gts 22 inch mpwer....sat for two
its got a dirty carb jet/s strip down fule lines and card give a good clean up to fule filter in tank on pickup pipe and clean carb jets anf any other fule parts
aways run it out of fule if your going to lay it up,,,
Oct 28, 2009 | Toro Lawn Mower With Toro Power Tools
Does not run at full speed unless choke is at 1/4 setting. I checked the air screen and it is clear. I replaced the gas with new fuel 50:1 mix.
its a blocked carb or filter
clean out all the fule pipes and filters
"""even the one in the fule tank on the end of the pick up pipe""" and retune carb when starting up again
ps,, iv never liked running on a 50:1 mix?
i do 40:1 if it smokes a little ,,,,,its got oil in it!
Oct 27, 2009 | Homelite Consumer Products MightyLite...
I have a roybi 31cc weed eater and the fule line has become brittle and has broken apart. I need to know the layout of the new plastic fule line. I purchased a new fule line at Lowe's. I do not know wich...
STEP (1) The fuel supply line has the filter attached inside the fuel tank. The other end of that line goes on the carburetor's SUPPLY NIPPLE.
STEP (2) Determine the primer bulb's flow direction by pumping it under water. The unused nipple on the carb (IF STEP 1 WAS DONE CORRECTLY THERE IS ONE UNUSED NIPPLE STILL AVAILABLE ON THE CARB) will have a section of fuel line attached to it and running to the SUCTION NIPPLE (or pull-side, as some techs call it) of the primer bulb.
STEP(3) The final piece of fuel line goes from the OUTPUT NIPPLE (or push-side, as some techs call it) of the primer bulb and is routed back into the fuel tank as a return.
If plumbed properly, the primer should PULL fuel thru the carb and NOT pump any fuel into the engine. Excess fuel should be pumped back into the tank on each and every press of the primer.
Hope this helps!
Sep 28, 2009 | Garden
Yard Machines Cultivator Logo
842 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
