Question about True TD-95-38-LT Beverage Cooler
I need to about copper line - True TD-95-38-LT Beverage Cooler
  • 37 Answers
Can u be little more precise in ur questioning ??so that we can solve ur problem
Posted on Mar 31, 2011
How do you cap off a flex copper refrigerator water line
Flex? Do you mean a braided line like this?
http://i.stack.imgur.com/9tE11.jpg
or a solid wall copper tube like this?
http://www.frankcondelli.com/staging1/store/image/cache/data/Camper/copper%20tubing%203:8-500x500.jpg
In the first case it should have a fitting on the end, usually female, for which you can buy a blind cap to screw in. See a hardware house.
In the second case you are best to sweat, or hard solder, a blind cap on the end. There are cold compression fittings using a teflon or copper olive
http://help.tradingdepot.co.uk/wp-content/uploads/2013/04/compression-nut-olive.gif
but they aren't generally recommend for terminating a pressurised line. If the line just has low pressure you could use one, and no heat is needed.
Jun 22, 2016 | Refrigerators
Want to switch my outdoor kitchen stove copper line to a rubber flex line. The copper line keeps kinking.
Hi Sam,
You should have the reinforced rubber line anyway for safety reasons,
A dealer should be able to get you a replacement line that has the correct fittings on it.
Feb 04, 2014 | Dutchmen 2011 Fourwinds 311BHDS
How do i fix the plastic line going to the hydraulic clutch
I had same problem with my bronco I used 5/16 copper line and I just cut the two end off the old line then I got two 5/16 unions (brass compression fittings) custom bent the copper line where I needed to and then used the two unions to attach the old end's work very well and is holding pressure awesome been driving this way for about five years now it took a lot of trial and error bending the copper line but it'll get ya back ont the road
Feb 14, 2013 | 1985 Ford Bronco II
After compressor turns off it leaks air from pressure switch
Sounds like you have a tank check valve leaking. It is located in top of the tank. The copper discharge line from the compressor goes into the check valve. Make sure there is no air pressure in the tank. Then Remove the large copper discharge line. Also remove the small copper line from the side of the check valve. Once the lines are removed you can remove the check valve. Most of the time the check valve needs replacing. Sometimes they have large pieces of trash holding them open.
Aug 31, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
I have a copper pipe behind my fridge that needs to be connected to the fridge for the ice maker/water to work. What connecting hose do I need and how do I attach it from the copper pipe to the fridge?
use a 1/4 in nut and ring this is a very common connection. most lines will have the nut on the line .. some friges use a J Q connection on the valve and you will just have to push the line into the socket till it bottoms and your done. very simple . mm hotp this helps .. the water line pt # for your model is 218976409 and does use a 1/4 line connection and if your use this your will need a 1/4 in line coupler to connect from this line to your copper line . mm feed back pls ..
Jan 01, 2011 | Frigidaire FRS3R5EMB Side by Side...
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Hello! The copper line is broken where it attaches to the cooling unit. Is it possible that the line can weld? Thanks
It can probably be soldered ... then recharged. Seek help from your professional RV repair shop.
Jul 13, 2010 | Dometic Rooftop RV Air Conditioner
Copper waterline is broken
Hi .. there should be piping connectors at each end of the tubing. I would disconnect those connectors andtake them to the building supply store and get new fittings and a new supply hose. The new hose does not need to be copper,. you do not need to cut the existing fittings off the wall or the fridge, the new fittings, or new hose can connect directly to the old fittings. my tool of choice is a pair of crescent wrenches
May 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
True TD-95-38-LT Beverage Cooler Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
