Question about Panasonic SC-HT830V System
Any idea where I can get a 1.6A 125V fuse - Panasonic SC-HT830V System
  • 635 Answers
  • vick538054 Apr 01, 2011
    I need 125v fuse exact 1.6ay not find it
How to change fuse
See Service Manual, fuses F7001 (6,3A), F7002 (1,6A), bimetal switch (page 17 - power unit, page 33 - Checking the power unit, page 126 - gray areas of the wiring diagram, fuses F7001, F7002):
http://diagramas.diagramasde.com/otros/XVZ10000.pdf
Apr 13, 2015 | SharpVision XV-Z10000U Multimedia...
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
May 30, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
1.25A/125V fuse
If you live in the U.S or Canada, you should be able to get this item at any Radio Shack/The Source stores. Hope this helps!
Nov 11, 2013 | JVC XL-R5000BK CD Player
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
35505 power on problem
When pressing power switch the green LED blinks once,
Oct 25, 2008 | Mitsubishi CS-35505 35" TV
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Panasonic SC-HT830V System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
