Need filters what size and where do we get them
    Scholar:
  • 133 Answers
Filters are the size of your air return duct at the furnace and can be found in hardware stores and builder supply stores like Home Depot.
Posted on Mar 31, 2011
I need to know the size and type air filter for my Trane XR90 furnace
The filter size is printed on the filter. If the old one is missing, then you need to measure the slot that it fits in. Depending on the installation method and supply air duct work, it is hard to say what is being used. They can be 17 20 and 24 inches depending on the location and size of cabinet.
Mar 11, 2017 | Filter Heating & Cooling
Need to know what filter i need for furnace
This is probably not a factory specified size. You need to look at the return to your furnace. There should be a frame or housing for the filter. Measure it to see what size you need. These are often customized by the installer to meet the configuration of your ductwork. You need to measure how tal and how wide, but also how deep (thick). If possible always get a pleated filter, and not one of those "horse hair" cheap ones.
Jul 27, 2016 | Filter Heating & Cooling
What size filters do I need
the filter on the side will have a size on it such as 20x20x1 I recommend a fiberglass filter you get better air flow.
Aug 09, 2014 | Comfortmaker FVM4X2400A Air Handler,...
What size of sand filter hayward s711
711 is the style of valve head and goes onto many different sizes of filter body. there is usually a tag on the filter body to indicate the size as well as how much sand to use for that filter. if that tag is missing, measure the diameter of the filter body as, again, that will let you find the information you need
Apr 30, 2014 | Hayward SAND FILTER, PRO SERIES
What size pmp do you need to run with a s310t filters310t
check size of pool and filter for flow rate and change over and plumbing size and distance from pool filter is
Aug 17, 2013 | Hayward SAND FILTER, PRO SERIES
What size filter do I use
Look for any tags on the unit, many times they will list the size needed. Otherwise, you will need to break out the tape measure and see what it says. Filter sizes are a little iffy, so you most likely wont find the exact size, it will tend to be off by a 1/2 inch or so.
Apr 02, 2013 | Heating & Cooling
Need to know the filter size
The filter size should be on the filter you remove from the return air duct on a split system. If you can see the old filter take it out. The size will be on the side that is probably obstructed by the sides of the grill holding it in place.
Aug 03, 2011 | Heating & Cooling
What do I need to do an oil change on a 2003 gmc envoy?
1. Ramps or jackstands (do not do this with only a jack)
2. Appropriate wrench to fit the drain plug
3. Filter wrench for your filter size (when you buy the filter you can decide which size you need - there are 2 sizes)
4. Drain Pan
5. Oil filter and Appropriate amount of oil (recc - 10W30)
6. Creeper for comfort if you prefer
7. A bundle of rags
Jan 14, 2010 | 2003 GMC Envoy
What size filter do I need for a Nikon D40 and what size filter do need for aSigma 70-300mm Thank you
Hi!
Usually the diameter is written on the front of the lens. You can use lens with different diameters on this camera, it really depends on the lens, but it will most likely be a 58mm.
Tom
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens filter size.
The filter size for the FZ20 is 72mm.
May 19, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
