Question about Zanussi Kitchen Ranges
I need a door hinge fortop oven zanussi model ZMD 905 W
  • sabiston Aug 06, 2008
    I live in Australia. I have a zanussi double oven ZMD 905W Product NO 949700069, SerialNUMBER 74818472. i NEED A DOOR HINGE FOR TOP OVEN. Your previous rep assumed I lived in Europe.
    Hope you can help.
    Many Thanks
    Colleen Salkeld
    Genius:
  • 1,665 Answers
See if this element fits to your model
Posted on Aug 06, 2008
    Novelist:
  • 106 Answers
Below is the direct link where you can order the particular part. Also, it will show the amount of particular part that you want to order.
CLICK HERE TO GO DIRECTLY ==> GO
That should answer all your concerns.
thank you so much.
adonscott
  • Guardson Nunez
    Guardson Nunez Aug 06, 2008
    The first link that i gave you was for EUROPE. Below is the direct link of online store located in AUSTRALIA where you can order the particular part. Also, it will show the amount of particular part that you want to order.
    CLICK HERE TO GO DIRECTLY ==> AUSTRALIA SHOPPING
    thank you so much.
    adonscott
  • 319 Answers
I believe that you are in Eurpope, Yes?
If so, I have a distributor that can help!
Check out this website!
Have a great day!
Brian
Posted on Aug 04, 2008
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE
  • Priya darshan Aug 05, 2008
    ok,so you live in Australia.Then the only way to get the parts is to
    contact Zanussi and they will ship the required pars to Australia.
    Phone: 08 705 727 727
FB 510 Cuisinair built in oven - how to replace door hinges and where can new hinges be obtained
Assume you have lifted the door off the oven. You may have to dismantle the door to replace the hinges. Take a hinge to an electrical appliance parts supplier to get new ones or ask stockist of this brand.
Jan 03, 2011 | Zanussi Ovens
The inner pane of glass has smashed on our Zanussi ZBF 560 x single oven. I cannot find a way of either replacing the pane or the oven door as the hinges seem concealed Thanks
You will find some very helpful videos on how to do this by going to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter--- CLEANING OVEN DOOR GLASS or REPLACING OVEN DOOR GLASS,
You should be able to get all the imformatoin you need here.
Dec 02, 2010 | Zanussi Ovens
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Feb 14, 2009 | Zanussi ZBF360X Electric Single Oven
Zanussi ZBF 660 oven door requires removing to access replacement of inner glass
Hi BisseeCath,
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Oct 10, 2008 | Zanussi ZBF660 Electric Single Oven
I live in Australia and I need a door hinge foa a zanussi double oven
ok,if you live in Australia then the only way to get the parts is to contact Zanussi on and they will ship you the part to Australia.
Aug 05, 2008 | Kitchen Ranges
Oven door of Zanussi260X
If it is the same as the Zanussi ZBF 660 X then to remove or re-attache the door:
Regards,
DIYDIM
Jul 20, 2008 | Zanussi ZBF260 Electric Single Oven
Inside glass of zanussi oven
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Regards,
DIYDIM
Jul 11, 2008 | Zanussi ZBF260 Electric Single Oven
Oven door
open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Jul 01, 2007 | Zanussi ZBQ365 Electric Single Oven
Door
there are various ways of doing it but essentially you have to lock the hinges before removing door. sometimes a little arm which flips up or a circular slotted plate on the door
Mar 13, 2007 | Zanussi ZBS963X Electric Single Oven
Kitchen Ranges Logo
146 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
