Question about Sanyo Televison & Video
Screen is almost black with just al little bit of highlights
  • 1 more comment
  • wagmaster55 Mar 31, 2011
    dp50747 sanyo 50 in lcd
  • wagmaster55 Apr 02, 2011
    there was no whining problem whith my problem discription I believe the reply was uncalled for the tv is three years old thus no warranty has been trouble free till now. the problem is that the picture has gone nearly to black is there a projection bulb in this set or is it a different problem
  • wagmaster55 Apr 04, 2011
    modle number is dp50747 sanyo
  • 15,935 Answers
The backlight has failed. Without a model number, it is impossible to say if the backlight is replaceable. Most units are connected directly to the panel - and replacing the panel is expensive.
It is recommended to purchase new... as replacement will cost more than the unit cost originally.
Thanks!
Posted on Apr 02, 2011
  • Sanyo Master
  • 2,098 Answers
May I know the brand and model no. of your unit to assist you further?
Jdvillanueva
Posted on Mar 31, 2011
  • Jdvillanueva
    Jdvillanueva Apr 04, 2011
    Hi again, this symptom indicated that you're bulb was came to its end. This was not totally dead that's why the picture can barely viewable . You must replaced the bulb to back the unit to normal operation again...
    Genius:
  • 1,622 Answers
Sanyo is one of the most reliable tv products. Sorry you are having trouble. But, you should have returned the unit or sent it to warranty when you first acquired it - for the whining problem - because it is not normal.'
It will require a replacement of the high voltage flyback transformer and perhaps replacement of the horizontal output transistor - usually done at the same time. The cost will be over $150. If you really like the set it is worth it. If you were thinking about a new set with the advanced technology such as wide screen and hdtv reception, now would be a time to think about it.
Also try and get in touch with Sanyo - the number is in warranty section of owners manual - described the problem. Apparently this is not an unusual problem. They are sending me a USB device that apparently reprograms the software
Let me know if you have further questions.
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Apr 02, 2011
    there is a projection bulb but you need to replace the bulb inside the TV.
Screen flashes L then 1 and will not make copies
Hello sir; L-1 it means scanner problem, open the cover, press start to make a copy, if the mirror move out and can not go back or move out little bit and go back, then you have to replace " home position senser " if after you press start key it not move any, then you have to replace mirror motor.
Jan 23, 2010 | Sharp AL 1631 Copier
BLACK SCREEN · I TRIED TO RESTART MY PHONE AND NOW THE SCREEN IS ON BUT STAYS BLACK
I feel your pain. My g1 droped, the screen cracked, now 3 weeks later my screen turns black. Not even turning it off or removing the battery for hours changes this. However, i found if you wiggle the screen just right sometimes you can get your screen back... for a little bit.
Oct 17, 2009 | HTC G1
Polar F11F Error 16
you need to hold down all 4 or 5 buttons at once. This will reset your watch and bring up the message "welcome to polar fitness world". Press ok button 1x to start your setup process.
Apr 16, 2009 | Polar F11 Heart Rate Monitor
Magnavox t.v. Model # TS2760 C101 with black box on screen
To fix this problem you need to go to the text probably in
the closed caption or thereabouts. Go to the text highlight it and cut the text OFF
It is very simple to cut the text off...a little practice and persistance and you
will find it.
Mar 09, 2009 | Televison & Video
Motorola w755 front screen
describe "a little bit at a time". do you mean for a few seconds, then goes black? Or do you mean for a fraction of a second?
Dec 25, 2008 | Motorola Mobility MOTO W755 Cellular Phone
MY SHARP AL-1010 IS MAKING A CLICKING SOUND AND THE PAPER JAMS
clean up paper delivery roller, if paper come out little bit out and stop, then you have a paper exit sensor damage
Dec 14, 2008 | Sharp AL 1215 Black and White Copier
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Televison & Video Logo
66 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
