Question about LG 42LC2D 42 in. LCD HDTV
I have a 42 inch Magnavox lcd tv and the power up will not go on. Not getting any light read out on the LED I am thinking its a main power fuse wondering what the part number would be and where to buy it at
  • LG Master
  • 2,098 Answers
Hi rboivinmes,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit this link for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
Here's a link for parts replacement. Just type glass fuse to the search engine if you found that it is in the power supply board.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Mar 31, 2011
  • LG Master
  • 12,061 Answers
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Magnavox/RCA in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Sanyo 42 inch LCD TV - Could the back light inverter be the cause of not getting any power? There is a red light on it and that is all
> Could the backlight inverter be the cause of not getting any power?
If the set uses a fluorescent backlight (many use LEDs instead) it will not prevent it from turning on so at least audio should be present.
With no backlight. you will not see any video but the set will receive and audio will work.
If you replaced the (main) power supply with a 'pull' (removed from another set) it may have failed like your original one.
Jun 25, 2015 | Sanyo Televison & Video
42 inch magnavox tried to reset. I have no picture but have sound when I play dvd
If the power LED lits, and the set do not come out from standby; the fault is with its main board. If there is no Power LED at all, the fault is with its main power regulator board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 08, 2014 | Televison & Video
No picture no sound amber light on
There's no 3.2 v off U33 (main module) I wasn't able to find AMC1117, So I used a Radio shack LM317T. this supplies 3.3v to video processor and associated circuit. this won't blow fuse.
Nov 12, 2013 | Vizio VX42L 42 in. LCD TV
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Magnavox 42MF437B 42-Inch 1080p LCD HDTV will not power up
First place to look will be the power supply module, look for bad caps, check the output DC voltages, it will be an in-depth troubleshooting to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 11, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
277 people viewed this question
Computer Repairing
Computer Repairing
