Question about Garden
The machine dont have force the model is D18C
My 65 is moving VERY slowly and I dont think the bobbin is any longer connected correctly...I am new to sewing
What is the machine brand, assuming the model is 65? That will make a big difference on how your question can be addressed.
If it is a mechanical machine (not computerized), more than likely it needs a thorough cleaning, oiling, and adjustment. If it is mechanical, avoid using it until the issue is addressed. Forcing the motor to try to move stiff parts could damage it.
Nov 07, 2016 | Sewing Machines
I have kenmore model 385.12914, while i was using, all of sudden it got very heavy and stopped working , now the wheel is jammed . I opened it up tried to see if any thread got stuck, could not find...
will it turn free'r backwards , have you ck bobbin under needle platform , might be a snag there dont force it if it wont turn then theres a reason youll have to find it
Jan 08, 2015 | Kenmore Sewing Machines
Celebrity 550 the needle dont pick up the threat of the bobon
You have forced the machine out of timing ! You need to either take it to a sewing machine engineer or look up how to adjust the feed timing on you tube ! Good luck
Aug 28, 2014 | Sewing Machines
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
Jul 23, 2012 | Ricoh Aficio MP 161 Black and White Copier
Compaq evo need ethrnet drivers intels drivers dont work
I have the same? machine (model D510S) and can be tricky to track down drivers. I can probably locate them for you and give you the link if you provide your model no. (should be on case near the front).
Sep 15, 2009 | Compaq Evo D500 PC Desktop
Error code F-01
Press "end of cycle button" for over 5 seconds, it will unlock. Note: the door should be opened only on hearing a click, or wait for 2 minutes after the wash completes.
I need a rating please, dont forget(!)
Dec 27, 2007 | Hotpoint Ultima WF860 Front Load Washer
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
