Question about Refrigerators
We have a taylor 754-33 ice cream machine. the 2 barrels get cold but the tray on top where the flavor mix sits doesn't.. so in the long run the flavor mix gets spoiled.
  • 132 Answers
There could be two reasons for this
Some of the refrigerant has leaked out.
The compressor is not working properly.
In either case a technician can help fix the problem
Posted on Apr 01, 2011
  • stephnrich1 Apr 13, 2011
    call taylor most of the time the temp prope goes bad 45 dollar part 125 installed
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Chocolate ice cream has turned a funny color and that side is running loudly
A grey color often indicates the beater bar is grinding on the inside of the barrel. What you may be seeing is metal. Be sure your beater bar is not bent. Visually inspect the inside of the barrel for marks. Wear is not normal. If you see wear and the beater bar is not bent, be sure all plastic bearings and components are installed. Also, it is normal to have some drip and lube in the drip pans, excessive amounts usually indicate problems though. Hope this helps you.
Mar 14, 2013 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Machine runs and mixes. Compressor seems to run but mix will not thicken. Seems like mix is not getting cold enough. A water cooled unit.. Tried to bypass water intake switch so water was always...
if its a water cooled unit when the compressor is running water should be running thru the valve, if it isn't be sure you have the water correctly hooked up and its cold water, if it is and still no water you have a bad valve
Apr 03, 2011 | Taylor 632-27 Ice Cream Maker
I was wondering, I have two two barrel taylor soft serve machines from an old Carvels Ice cream store. The model numbers are c-712-33 and 8771-33, They were on a glycol machine, DO you have to have a...
This particular Model C712-33 goes into a heat cycle every 24 hours depending to pasturize the mix ,usually good for two weeks.Then the machine must be brushed cleaned.The timer can be disabled as to allow for regular operation.
Jan 18, 2011 | Taylor 632-27 Ice Cream Maker
Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
