Question about Microsoft Office Publisher 2007 for PC
I have developed a document with text and graphics in MS Publisher which I want to print using three sheets of 8.5" x 11" paper. How do I organize 12 half pages into the proper sequence so that my color laser will print the document on both sides of three sheets of paper, stacked one on top of another, to give me the completed project. I do not have a problem understanding/using my printer.
5 Suggested Answers
  • 16 Answers
SOURCE: I'm using MS Publisher 2007 and pdf creation problem
  1. On the File menu, click Publish as PDF or XPS.
  2. In the File name list, type or select a name for the publication.
  3. In the Save as type list, click PDF.
  4. Next to Optimize for, click Change.
  5. In the Publish Options dialog box, click the optimization in the Specify how this publication will be printed or distributed list that matches the needs of the publication. For example, if the publication will be distributed online and print quality is less important than a small file size, click Minimum size. If the quality of the printing is more important than file size, click High quality printing.
  6. Click Advanced to display the entire dialog box, and select the settings that you need. (Find links to more information on these options in the See Also section.)
  7. Click OK.
  8. In the Save As dialog box, if you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer, and if the Commercial Press option is not selected in the Publish Options dialog box.
  9. Click Save.
Posted on Feb 12, 2009
abhvp
  • 148 Answers
SOURCE: Trying to print a document with publisher 2003
Have you restarted Print spooler service?
Posted on Mar 20, 2009
Squirm57
  • 152 Answers
SOURCE: Trouble printing book made in Word 2007 using a HP psc 1315 print
Select the Page Layout tab, in the page setup group, select margins, The at the bottom, select custom margins. on the margins tab about 1/2 way down, select the down arrow next to Multipl epages and select 2 pages per sheet. Print a couple test pages and see if that is the setup you need.
Posted on Apr 06, 2009
  • 489 Answers
SOURCE: Photographs randomly disappear each time a document is used.
Before you open up Publisher and this document, open up task manager and note how much RAM is used as well as your paging file usage. After you open the document, take another look at your RAM and paging file usage again. If both have increased dramatically, you may want to use smaller images (via compression for JPEG files or lowering the resolution of the images first). Or you could invest in more RAM for the computer.
Posted on Jul 07, 2009
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Tip
Copier Lingo, Jargon, Keywords Explained
When you're shopping for copiers you'll often see a bunch of acronyms or words that don't make any sense to you, the layman. That's what we industry insiders are for, to help translate these words and phrases into coherent thoughts. If you come across any copier lingo that isn't on this list, just contact me and I'll let you know what it means, then I'll add it to this page for future reference.
In alphabetical order:
  • ADF = Automatic document feeder. Every machine since the turn of the century has had one of these. There are variations of this term. See RADF and DHADF.
  • Bypass Tray = an additional paper source that normally supplies envelopes, labels, or heavier paper. It can be used to supply any paper that you don't have readily available in your regular paper trays
  • CPM = copies per minute
  • Developer = A finely ground metal material that adheres to the drum magnetically to transfer an image onto toner, which makes an image on your paper.
  • DHADF = Dual head automatic document feeder. Sometimes call scan squared, this feeder has two scanners that scan both sides of an original in one pass without flipping it around
  • Driver = A print driver is installed on your computer to communicate properly with your model of printer.
  • Drum = The drum is an essential part of the copy process because it "receives" the image from the developer and transfers it onto the paper with toner
  • Drum blade = The blade wipes the drum clean on each rotation. If you have an old drum blade you'll start to find lines on your prints.
  • Duplex = 2-sided printing, copying, or scanning
  • Finisher = An additional piece of hardware that enables the copier to staple and offset sort your printed documents
  • Fuser = The hot section of the copier that fuses the toner off of the drum onto the paper.
  • LCC = Large capacity cassette. This cassette will hold 3,000 or more sheets. It is an additional cost, hardware and adds to the footprint of the copier
  • Ledger Paper = 11 x 17 is commonly referred to as ledger, although it's more often just called "11 x 17"
  • Legal Paper = 8 ½ x 14 paper is commonly referred to as legal
  • Letter Paper = 8 ½ x 11 paper is commonly referred to as letter
  • MFC = Multifunction copier. Implies that it prints and scans along with copying.
  • MFP = Multifunction printer. Most "copiers" nowadays are MFPs.
  • PPM = pages per minute, a modern day variation of CPM since it implies more than just copies
  • RADF = Reversing automatic document feeder. This feeder will automatically flip an original to make a two-sided copy.
  • Saddle Stitch = Another form of finisher that will fold and staple documents like a booklet
  • Sorter = Another term for finisher. It will offset sort your documents and some manufacturers have a stapling function.
  • Toner = Toner is the "ink" of laser printers. It's a VERY fine powder that moves like a liquid, use caution when replacing your toner cartridge. Most toner cartridges nowadays have no open holes for toner to leak, but you should still be careful when handling one.
This should be a big help if this is your first time shopping for the correct copier for your office. If you have found this page you're probably in the process of shopping for a copier, so why not Request a Quote from me while you're at it?! I reside in Houston where I provide free delivery and installation of anything I sell, and I work with network of Sharp dealers all over the USA to get you what you need and have it installed by a professional. Don't delay!
on Feb 09, 2015 | Sharp Office Equipment & Supplies
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
I am trying to make labels for cd's but they are not printing correctly. The sheets show the cd to the side of the page but it's only printing straight down the middle so it's not letting me print...
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
Jul 27, 2010 | Avery DesignPro Deluxe CD-ROM...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Converting word formatted data in CStriing to MS publisher
Why not use Word Automation? You instantiate an object with a reference to Application.Word, load your document, then use the built in functions to extract the text from the document and paste it into the MSP document.
Jun 30, 2008 | Microsoft Computers & Internet
MS Publisher 2003
i can not open microsoft publisher document
Apr 17, 2008 | Microsoft Office Publisher 2003 for PC
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Jun 17, 2007 | HP DeskJet 1600C InkJet Printer
Microsoft Office Publisher 2007 for PC Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
