Question about Canon PowerShot A430 Digital Camera
Image too bright plus the white lines
have you found any solutions on your canon image problem....too bright plus white lines on the pics..
Thanks.
  • zumba Sep 30, 2008
    outside photos, too white, color photos inside have lines through them. LCD canon logo at back of camera has lines through it. Video o.k.
Hi!
I had a similar problem with my powershot A430 recently. I took it to a canon service center and they identified the problem as "shutter unit problem". My cam was under warranty so they fixed it for free and also replaced my lens (even though i didnt ask for it!). :-)
Take your cam to canon; they will fix it. All the best!
-Aashish.
Posted on Oct 13, 2008
Unclear, too bright picture
First try defaulting your camera to factory settings. Go to the Menu, select Reset, press the right arrow, use your up or down arrow to find Reset again, then press Set. Your manual can be found at http://support.casio.com/pdf/001/EXS500_e.pdf
May 18, 2010 | Casio Exilim EX-S500 Digital Camera
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Photos come with horizontal stripes and too bright
Hello naushed,
I had the same issue with the white horizontal lines with myCanon Powershot series camera too. When taking pictures, I get the horizontal lines. In daylight, I almost cannot see the pictures because it gives me very bright output. In darker areas, the picture can still be toleratedbut white lines are still there. Although when I am taking a video,the quality is good.
I was able to read that there is one part insidethe camera's mechanism that is faulty. Its a CCD problem. You should bring this to a CanonAuthorized service center and they should replace and fix the faultypart, free of charge. I got my Camera fixed for FREE! I was able to do macro shots again.Trust me and go to canon. What I did is to print this advisory fromcanon itself. And show it to them.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
As part of their advisory:
"Effective immediately, and regardless of warranty status, Canon willrepair, free of charge, the products listed above exhibiting theabove-mentioned malfunction if Canon determines that the malfunction iscaused by the CCD image sensor. Canon will also cover the cost ofshipping and handling in connection with this repair.
Hope this helps.
Nov 18, 2009 | Canon PowerShot A430 Digital Camera
The lcd screen shows white image when taking outdoor photo
i was taking picturres with my canon A470 digital camera and when i review the pictures that i take, the pics were very bright that you cant view well the pics. what is the problem with it? it just suddenly happened like this.
Oct 25, 2009 | Canon PowerShot A470 Digital Camera
White lines across stiils
You can suspect that the ccd has a problem. Here is a link to Canon Repair .
Call the Canon Repair 800 number, they will pay to and from plus repair the camera to fact. specs.
Sep 21, 2009 | Canon PowerShot A95 Digital Camera
Horizontal Lines throughout the images
That Canon Expert is not giving ur correct info i have done huindreds like this it is 100% CCD Fault and it do have a CCD unit installed either he is not a tech or he is trying something on u , pls dis regard his advice and kindly see below just call canon
CCD FAULT has various SYPTOMS like
Over Exposed Daylight pics indoors ok but extra light is a problem
might be puikish redish or purple tones
Streaks noise or complete Black or Blank pics
dont waste time just call canon
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 28, 2009 | Canon PowerShot A430 Digital Camera
HI All of a sudden, there is lets say no more image on the display or the image is purple and full of weird lines. No image at all and when I click to take a picture everything works out well: the flash...
BUT NOW U HAVE FOUND SOLUTION
CCD FAILURE !
but u will get it repaired Free of Charge as Fuji has taken notice as all manufac and i got my S5000 repaired Free from Fuji just call them tell them about BAD CCD it is a known manufac fault in thousands of cameras just call them quick
www.fujifilm.com
see this thousands suffer from this
http://www.imaging-resource.com/badccds.html
May 08, 2009 | Fuji FinePix S5000 Digital Camera
Outdoor pics all white
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 27, 2008 | Canon PowerShot A95 Digital Camera
Vertical lines & white screen outdoors
I've seen similar symptoms in broadcast cameras and it can sometimes be compensated for by lowering the "v-sub" voltages to the CCD. Not sure if that applies to your camera but it's an idea to check out.
Unfortunately it's not the kind of adjustment for a user. It's more likely found in a service manual for
technicians.
Nov 04, 2008 | Samsung Digimax S500 Digital Camera
Image result over bright at day light
Same problem here with the A430 I contacted Canon tech support and it looks like I'm going to be buying a new camera because it's not worth the effort and money to get it fixed. Rest assured, the new camera will not be a Canon.
May 24, 2008 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
375 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
