Question about GE Microwave Ovens
My GE spacemaker model JVM1630BB doesn't heat up the food anymore. The interior light works and the turntable.
  • GE Master
  • 6,771 Answers
The problem is generally caused by a defective magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. Professional repairs with parts and labor can be very costly "approach the price of a new one"
Posted on Mar 31, 2011
  • GE Master
  • 3,051 Answers
Hello there and than you for choosing fixya
whenever a microwave stops heating up food there are only 2 things that can make this happen
1 is the mengatron is faulty and 2 is the power inverter that is bad butthis is kind of unlikly so i will stick with the mengatron here is a idea of how it works and how to test it ok
The microwave oven is a very dangerous appliance to work on. For your personal safety, we respectfully ask that you read, fully understand and be prepared to follow carefully the list of very i
The following resistance tests will conclusively reveal a magnetron that is shorted or one that has an open filament winding.
Test 1
1. Unplug the oven (make sure the oven is completely disconnected from any power source)
2. DISCHARGE ALL HIGH VOLTAGE CAPACITORS. (Procedure)
3. Carefully remove all leads from the magnetron terminals. Proper wiring is important so make notes of the wire locations.
4. Set the ohmmeter to its lowest resistance scale.
5. Measure the resistance from one magnetron terminal to the other in either direction.
6. The magnetron filament resistance should be less than one ohm.
Test 2
1. With the meter set to the highest resistance scale, check from the magnetron terminals to the metal magnetron housing. (Be careful not to touch the meter leads as this will result in a false reading).
2. The meter should read infinity (open circuit) regardless of meter polarity.
3. Even a slight reading would indicate a defective magnetron.
Replacement Considerations
1. Be careful not to strike or touch the antenna dome area
2. Be sure to transfer any add-on parts, such as an air duct or thermal fuse
3. Insure that the wire mesh RF gasket is intact and in place
4. Examine the rim of the opening where the magnetron dome is to be inserted into the waveguide. Smooth out any irregularities, such as dents, pits, and burns. The rim surface should be bare metal, smooth to the touch. Use light-grade sandpaper - do not use steel wool.
5. If possible, perform and RF leakage check around the magnetron
6. If there is evidence of poor terminal connections (i.e., discolored, burned, pitted connectors), repair or replace the slip-on connectors on the filament leads
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE spacemaker model JVM1630BB doesn't heat up
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Listen to that and compare it to yours.
If it sounds much quieter than usual, I would suspect the top door switch (called the secondary interlock switch) or its mount. See this file.
If you only need a switch, you can order a universal type here for $5 postpaid.
If it sounds louder than usual, you may have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If it's within the magnetron portion of the warranty (usually 5-9 years) G.E. will send you a new magnetron to install yourself. Call them at 888-239-6832.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You should be able to check out and replace the door switch by removing the controller without taking the oven down from the wall.
But to access and replace the other parts, you can download GE owner's manuals and installation instructions here if you want.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Posted on Dec 13, 2009
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
My microwave does not heat anymore. The turntable works and the light works. How expensive is it to repair?
the heating source is the magnetron and it is not cheap .go to searspartsdirect.com and price the new one. you only need to enter your model #
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
At
Dec 13, 2009 | GE Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need GE Spacemaker parts..
SEE http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
321 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
