Question about Coleman Heating & Cooling
I have a 1986 Fleetwood Motorhome with Coleman Delta T air conditioners. The compressors cycle on and off at aproximate 1 minute cycles. I cleaned the condenser coils and there is plenty of air flowing through on each unit. What is the propable cause. Ross
    Scholar:
  • 133 Answers
Low on refrigerant.
Posted on Mar 31, 2011
How can i get to my heater core to replace it on a 86 cadillac fleetwood 5.0
BROUGHAM
1. Disconnect electric-al connectors at blower motor, compressor cycling switch, power
module and radio lead-in connections.
2. Remove righthand windshield washer nozzle.
3. Remove righthand secondary air inlet screen from plenum.
4. Partially remove rubber molding above plenum.
5. Remove remaining screws and the primary inlet screen.
6. Remove blower motor.
7. Remove two screws securing compressor cycling switch to module and position
switch out of way.
8. Remove AC module cover attaching screws and the cover.
9. Disconnect heater hoses at heater core.
10. Remove screw and retainer holding heater core to frame top.
11. With temperature door in max. hot position, reach through temperature housing and
push lower forward comer of heater core away from housing, then rotate core
parallel to housing.
12. Remove heater core.
13. Reverse procedure to install.
Dec 23, 2010 | 1986 Cadillac Fleetwood
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
Freezing up have to manuely cycle compressor
3 things could be the cause,
1 low on freon,
2blockage in the metering device
3 blockage in the air flow
The only one of the above that can be checked without special tool is the blockage in air flow. Check the coils on the inside of the unit to make sure they are clean and dirt free. Now do the same to the outer coil. If the coils look in good shape then you will need to contact an a/c tech for checks on the first two problems.
Dave
Mar 31, 2010 | Coleman Mach 15 Air Conditioner
After a cooling cycle, when the thermostat call for more cooling, it take up to 5 minutes after the air handler starts for the compressor motor to restart. The top fan operates on the outside unit, but...
No, this cycle cannot be shortened due to the simple fact that this feature is in place to protect your system. Even if it could be, I wouldn't recommend it.
Mat
Jul 17, 2009 | Coleman Heating & Cooling
I have a coleman ac that cycles on and off , the
your system is shutting off on low pressure, you need to get it looked at to find a refrigerant leak
Jun 22, 2009 | Heating & Cooling
Have coleman roof air keeps cycling compressor on and off
that is normal operation, unless it does it frequently, like more than once a minute. if its cooling good but turning on and off to often there is a thermostat problem, and the it needs to be replaced
Jun 17, 2009 | Dometic Rooftop RV Air Conditioner
Coleman rv a/c
It is definitely with the compressor. It should more like you may have a weak winding in the compressor, you can a hard start capacitor (sp5 ) that will help the compressor on restart. Note that this is a last chance solution for a compressor.
Oct 01, 2008 | Coleman Mach 15 Air Conditioner
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
146 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
