Question about Sanyo PLC XU35 Multimedia Projector
I cant get the volume to work through the projector
Morning, I am playing a DVD on my computer and have connected it through my Sanyo PRO xtraX multiverse projector and cannot get sound, please help. Kayleen
2 Suggested Answers
  • 84 Answers
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Posted on Sep 25, 2008
petraman7
  • 1175 Answers
SOURCE: How do I flip the
All you need is in the manual.If you dont have a manual ,
check their website and do a search on your model number.
Download is free.
Posted on Oct 11, 2010
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Connecting Ibook G4 to Sanyo PRO xtrax projector
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Feb 02, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo pro xtrax
I am not understand the exact problem.
Can you pls explain briefly about your problem?
Dec 07, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Sep 03, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
157 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
