Question about Samsung HP-R4262 42 in. Plasma Television
I have the 42" Plasma
  • Samsung Master
  • 2,098 Answers
I'm online now on pay question, I can exactly tell you what parts needed to be replaced and I will assist you to fix it yourself.
Jdvillanueva
Posted on Sep 27, 2011
Hpt4254X/XAA Just clicks. Does not come on now. Stopped presenting a picture within last month.
Your TV need a through checkup. Main board, power supply regulator board, back-light inverter board need to be troubleshooted. Contact any service technician, or the authorized service center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 31, 2014 | Samsung Hpt4254 42 Hdtv Plasma
Can you tell me how to replace the capacitors on a sumsung plasma tv model code HPT4254X/XAA ?
It will be best to replace all of them at one time. Make sure about the polarity of electrolytic capacitors, when replace them. They have both +ve and _ve terminals, and should be noted the postion of fitting when your desolder out. If the polarity changes, they might explode when you switch on the set.
Jul 14, 2012 | Televison & Video
HPT4254X/XAA clicking noises? Cuts itself off and continues to make clicking noises as if it is trying to turn itself on. I've had cheap tv's for 20 years and no problem. I'm not...
The tv power supply board it is the 90-95% the problems and the causes.That the board where the tv power a/c cord plug into it.Those capacitors components parts the tvs corporation put on tvs are under voltages for low heat resistance most of the times and dies very quickly, to dies as times used a lot of tv on like 3 or 4 hours a day within a year or litte bit more.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes?Take the the tv aparts and check the tv power supply board carefully for dying and leakages capacitors components parts.These dying and leaking capacitors parts are alway bulges up or puffing up on to it tops.All these dying and leaking capacitors parts that are bulges up or puffing up on to it tops.All these dying and leakages capacitors components parts must have be replaced like the same Micro Fared and those voltages on the new capacitor parts u are replacing should be in higher voltgaes like 5 or 10 voltages higher than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 25, 2011 | Samsung HP-R4262 42 in. Plasma Television
2006 42" plasma has blank
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Samsung tv comes on for a little bit then turns off model number HPT4254X/XAA
Take the tv back cover aparts.Check the power supply board,that the board where the power a/c cord plug into it.U have tools like a soldering iron and a desoldering pump or a roll of desoldering braid and can do basic soldering and understanding electronic?Yes.Check the power supply for dying capacitors,will have bulging or puffing up on it tops.By replacing all these dying capacitors,will solved this problems.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 21, 2011 | Samsung HP-T4254 42 in. Plasma Television
I have a Samsung 42 " Plasma Model no: PS42Q96HD.
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills.
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBay sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
Feb 10, 2011 | Samsung HP-R4262 42 in. Plasma Television
My screen is broken where can i price a new screen for my 42 samsung plasma model # hpt4254x/xaa
Not worth replaced the screen,same as a new tv.Will not find new screen cheap,or the tv companies sell them out not cheap or reasonable price.
Jan 05, 2010 | Samsung HP-T4254 42 in. Plasma Television
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung HP-R4262 42 in. Plasma Television Logo
262 people viewed this question
Henry  Thomas
Henry Thomas
