Question about Honeywell Heating & Cooling
Have a dual zone system. When zone 1 is working zone 2 is getting air and vice versa. What is the problem?
    Scholar:
  • 133 Answers
Try reversing the wiring at the thermostat or control station between those two circuits. There should only be one wire to change for each zone. (Not a White one)
Posted on Mar 31, 2011
I have a deluxe wired heat pump and am enquiring what the 2 zones" are
Debi - "2 zones" usually indicate, 2 separate areas of the house(upstairs & downstairs). But, this usually requires two separate heat pumps for each area. That is unless, you have an electronically controlled damper system in your home's duct work. If that's the case, when one area calls for heat or AC, the damper closes to the other area and vice versa. If both areas call for heat or AC, the damper stays in the neutral position.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | LG Heating & Cooling
I have to hit the bell really hard to get it triggered
On dual trigger devices makee SURE you use a three conductor cable that has a tip-ring-sleeve connectors both ends. This is similar to a 1/4 inch stereo cable. Single trigger devices only require the tip-sleeve type cable. It is common to have dual triggers on the snare and in your case on a cymbal and often users use the cable intended for the dual trigger on one of the single trigger ones and vice versa so the dual doesn't work.
Apr 05, 2011 | Roland Cy12rc Dual Trigger Cymbal Cy12 Rc
I just got a new Boss Metal Zone MT-2 pedal 3 days ago(1-28-11) n when I press on it is not turning on???
Try the obvious stuff first.
  1. Check that it has a battery in it and it is installed the right way round.
  2. Only use top quality batteries (Duracell Ultra or equivalent) do not use re-chargeables as they don't achieve adequate voltage.
  3. If you are using a mains adapter try a battery instead as the adapter may be faulty (or vice versa)
  4. Some effects pedals will not switch on without a jack plug in either the input or output socket (or both)
  5. If none of that works it is probably faulty - take it back to the shop and ask them to replace it or prove it works
Jan 30, 2011 | Boss Mt 2 Metal Zone Effects Pedal
The RV i'm working on has 2 roof units,both start to cool then comp cuts off , there is 1 thermostat with dual zones,its on a 2006 motor home,it dorsn't seem like both would be bad
Can you get 1 to run good at a time, or does same happen when 1 only is run? Some RV's have an energy management system incorporated, that cuts power back to certain appliances when necessary. There were/are some units (RV's) that needed to be plugged in as well as generator running in order to run 2 AC units at same time. Let me know.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
111 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
