Question about Sanyo Televison & Video
I have my cable plugged into a reciever and my reciever is plugged into the tv but my tv is stuck on a blue screen that says Video and when I press menu, the only options it lets me access is picture and language.
    Habit-Forming:
  • 50 Answers
Try pressing the channel down button, alternatively your unit may be on auto-sense and since it doesn't detect any other available inputs it wont change. Try disconnecting the receiver, powering down the TV and connecting the cable directly. Alternatively make sure the receiver unit, which model is it BT?, is setup to output on the AV jacks. What all types of outputs does the receiver have at the rear?
Posted on Mar 31, 2011
Setup proscan tv
Newer tvs have a lot of input connections ( holes) and can be very confusing. With out knowing what kind of plugs you have I will try to help as best I can. First ,if you have a coax cable hook it to the corresponding connector. The coax is a pencil sized cable that has a center wire and a threaded nut. It will screw onto the threaded connector on the back of the tv. If you have RCA cables these will be color coded yellow for video red and white for audio plug these into the corresponding connectors. There may be more than one set of these connectors and may be marked input1 or input2 etc.make sure to write down which input you plug these into.you may also have colorstream cables there are three green red and blue. Some of the newer tvs don't have inputs for these but if yours does plug them into the corresponding colors. Another cable you may have is a s-video cable this is a single cable that has a multi pin connector on each end. Again find the corresponding connector and plug this cable in. The newer cable is called a hdmi cable and is a cable with a rectangular end. This one cable takes the place of the multi-pin s- video cable or the RCA cables. It also replaces the colorstream cables. If you were able to connect all your cables up. Turn on the tv. You may get a blue screen that says no signal. Don't panic take the remote and find the input button. Pressing the input button changes the tv to the various sets of inputs on the back on the tv. Press the input button several times waiting in between each press of the button for several seconds untill you find the input you connected your cables to. If your connecting a vcr make sure you have a video playing so there will be a signal for the tv to find. I'm not sure what a PVR is, but make sure it is playing some thing when you scroll through the inputs on the tv with the remote. Hope this helps.
Jan 03, 2014 | Televison & Video
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
My TV is stuck on Video with a blue screen. Is my
Change the input to cable or TV. Look in the manual and use your remote to scroll through the menu....
May 29, 2010 | Sanyo DS31520 31" TV
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
Blue screen: Not Support!
It sounds like you have no signal being detected by the TV. Check your connections to the TV from your cable box or satelite reciever to be sure they're plugged in tightly. If you have a DVD player or VCR, try watching something from one of them to see if you get a picture. If you do, then your problem may be with your cable box or satelite reciever, and not the TV.
Good luck.
Dec 01, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Connected to a sat. we have no sound when we put the T.V. to H.D
What cabling are you using? component? (blue red and green) or HDMI? if you are using component then make sure you also plug the red and white RCA cables in the "audio in" inputs. People commonly think that the component cables do it all but they only carry a video signal. If you are running HDMI through an AV reciever you may need to run an optical cable as well as most AV recievers (unless you buy top of the range) can only switch HDMI video but not sound.
Jul 05, 2009 | Televison & Video
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
Televison & Video Logo
117 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
