SOURCE: paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
SOURCE: The Ricoh Alicio SP C410dn
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
SOURCE: Printing stops on its own after printing a couple
SC285 is a line position adjustment error. It is possible the ID sensors are dirty. In order to get to them you have to remove the PCUs and developers as well as the transfer belt assembly. The sensors are behind the shutter that is next to where the upper most PCU would be inserted.
