Question about Pitco Frialator SG14 Deep Fryer
My fryer model SRTG LIGHT THE PILOT BUT WON'T LIGHT THE MAIN BURNER
  • Pitco Frialator Expert
  • 683 Answers
Check if the thermopile (cylindrical metal standing behind pilot assembly) receives enough heat from pilot flame. if it does, you need to replace the thermopile.
Posted on Mar 31, 2011
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
45C- Flame and pilot went out during operation, Pilot won't relight.
If your pilot is a manual ignition model, make sure that the thermopile is clean (free of soot), it is the cylindrical piece of metal behind the pilot assembly which is heated by the pilot flame, a very small amount of voltage is generated by it to open pilot and main burner valves of gas valve.
Jun 03, 2011 | Pitco Frialator 45C Deep Fryer
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
Pilot light goes out when burner turned on
Replace the pilot generator. You are not getting the millivolts you need when you turn on the fryer.
Tom
May 28, 2010 | American Range AF45LP Deep Fryer
Main burner too hot & 2nd burner pilot won't
Set t/stat to 250 degrees. If it does not shut off after about 5 minutes, replace t/stat.If shuts off, must be calibrated Pilot may be dirty, flame weak. If flame strong, replace thermopile(pilot generator). If weak, must remove and clean pilot orifice inside pilot.
Aug 29, 2009 | Keating Kitchen Appliances - Others
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
Imperial fryer
If your pilot lights up but the main burner doesn't light up then you have a bad pilot sensor or gas valve
Sep 16, 2008 | Imperial IFS50 Deep Fryer
Main burner will not light or goes out before grease reaches temperature.
before replacing any parts,clean out the pilot,burner orfices and burners.if this doesnt solve your problem replace the thermopile.call 18884hobart and get the parts dept.tell them you need a thermopile for the model of your fryer.95% of the time the t-pile goes bad.theres also the hilimit in the unit that kills the gas if the fryer gets too hot but i dont think thats the problem.also check all wiring connections to the gas valve (clean and free of grease).drain the oil in the tank and youll see 2 bulbs ones the thermostat bulb the others the hilimit bulb.make sure their secured to the bracket.
Jan 06, 2008 | Vulcan EF3 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
399 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
