Question about Amana Ovens
Oven temperature not right - Amana Ovens
  • Amana Master
  • 3,051 Answers
Hello there and thank you for choosing fixya.
Whenever your oven does not display the correct temperature this is due to a faulty temperature sensing probe this is a very common issue with all makes of ovens so dont feel left out lol any way what you will need to do is to contact your local appliance dealer and ask the if they have a temperature probe for your oven if not you can order it online thru repair clinic.com or appliance parts pro's .com all you need to provide them with is the make and model number of this oven ok ?
I have provided a picture of what this part will look like for you it is below this
Also this is a 34 dollar part
Posted on Mar 31, 2011
  • Michael Thomas
    Michael Thomas Mar 31, 2011
    and one other thing that may be going on is that your temperature setting part may be starting to go out so you may want to look in to this too ok
My old admiral oven doesn't get to the temperature I want, could it be the oven temperature sensor?
  1. You can do a simple at-home test.
  2. Purchase an inexpensive oven thermometer (the kind that hang from the rack are great but whatever is designed for oven).
  3. Then set your oven on 350 and wait for oven light to go out (indicating it is at temperature). Compare the temperature on the thermometer (it should say 350 but sounds like your results will be less).
  4. If it is not the same temperature you have SOME adjustment that can be made. Most oven temperature control switches have the ability to adjust/calibrate. Depending on make and model you may be able to pull the temperature adjustment knob off and see a screw and a slot. Loosen the set screw and turn the post slightly then re-seat the screw.
  5. Repeat the test on step 3 again and see if you are closer.
  6. If it got worse, loosen screw and turn the other way (and re-test).
  7. If it got better but not quite right, repeat the procedure.
  8. If you are unable to adjust to get the temperature correct you may have a faulty temperature sensor.
Nov 03, 2014 | Ovens
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 17, 2010 | Frigidaire Ovens
The ovens no longer get up to temperature. And if you do get it to a temperature, it does't stay at that tem. It just continues to get cooler.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Oct 12, 2010 | Jenn-Air Electric Double Oven
My oven comes on and reaches the right temperature but then it starts beeping and shows F-2 or an F-4 in the display window. Then it stopps cooking.
Your temperature sensor is inside the oven in the top rear section. It is metal about 3 inches long. You can remove it from inside the oven. The F2 and F4 codes is a bad temp sensor.
Nov 24, 2009 | Maytag CWG3100A Gas Single Oven
Programming a Lange Oven
go to partstown.com the have the manual for your oven in the top right corner
Jun 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
Oven wont bake at the right temperature
Sorry for the cookies have you tried going to the viking web site and downloading a manual on your oven. Usually they will explain how to calibrate the oven. Hope that this helps if not let me know please thanks
Dec 23, 2008 | Viking VESO176 Stainless Steel Electric...
Oven won't work
the oven sensor needs replacing, 2 secrews hold itin its locared in the upperleft hand corner on oven cavity, pulls right out and new one plugs in.
F3 Oven temperature sensor open Replace oven temperature sensor
Dec 02, 2008 | Frigidaire FGB24S5A Gas Single Oven
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
