Question about Whirlpool Duet GHW9150P Front Load Washer
It makes loud noice when spining or by hand it flops to one side?
  • 46 Answers
Noise when spinning, seems to be the bearing are worn out or broken. The washing machine needs to be opened while disconnected from the a.c. mains. It may be necessary to lift the drum out of the machine to get to this, if direct access from the rear is not available or awkward to get tools in.
At the rear of the drum there is a wheel connected to a belt. Beneath this wheel are some spokes (called a spider) which is bolted to the drum. This spider needs to be removed and the center bearing hammered or pulled out using a bearing puller (automotive garages use them) without damaging the spider. The bearing will have a rubber seal on top which can be removed with a screwdriver. Normally the seal and bearing is replaced as part of a kit. These are available on ebay, contact the seller with model number GHW9150P to make sure, see example search below.
http://www.ebay.co.uk/sch/i.html?_nkw=whirlpool+bearing&_sacat=0&_odkw=GHW9150P+bearing&_osacat=0&_trksid=p3286.c0.m270.l1313
When Replacing the bearing and add grease so that it is well lubricated.
Reassemble in reverse order
Posted on Sep 27, 2011
Hello.i need a help,my whirlpool 6sense washing mashine 9769b when spining do horible and loud noice! I try to find bearing but i dont cnow did my washing mashine have one.
Any front-loader machine will have a shaft and two bearings supporting the tub. You may need to remove the back to find it. Also, check to make sure that whatever supports the tub (spider attached to the tub and bearing shaft) is still intact. Some models have reputations for this spider corroding and failing in as little as 2 years.
Apr 12, 2016 | Whirlpool Washing Machines
DW makes a lot of noice when it's washing....squealy, whiney noice...very loud.
Hello Summer Summer - Often if the dishwasher is making a loud, squealing noise then it is recommended for the wash motor to be replaced. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directly to determine what may be causing the issue at hand.
Mar 12, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
MY WHEELWRITER 6 WAS WORKING FINE UNTIL TODAY IT STAYS ON THE LEFT HAND SIDE AND WILL NOT MOVE TO THE RIGHT. IT MAKES A LOUD NOICE. I DO NOT SEE ANYTHING STUCK AND THE BELT IS INTACT HELP
Check for objects and debris under or around the carrier, with it off see if you can move the carrier back and forth, check the battery pack to be sure it hasent be come disloged. If you can move the carrier put some WD40 on the silver shaft it slides on.
DickyO
May 13, 2010 | IBM Office Equipment & Supplies
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
1994 Oldsmobile Bravada - Driving - Loud Noices
Sounds like worn Constant Velocity Joints (CV Joint)
to me.
Feb 27, 2010 | 1994 Oldsmobile Bravada
Loud roaring noice
have your hub bearings checked you have at least one bad one!
May 07, 2009 | 2004 Dodge Ram
Charger makes loud whining noice
they have a cpu fan in it, and unlucky for you you cant buy anthother part, you either get a new one, or try sparaying some WD-40
May 02, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
When spining it makes very loud noise , like aeroplane when start
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
