Question about OEM Systems Athenatech 400W ATX V2.01 Power Supply High Quality Excellent Performance Popular Modern Design (PS400WX1) 400-Watt
I just installed a new power supply - ATX V2.01 Model V-400. Everything works fine, except both my CD rom units do not work. There is power connected, because they open and close, but in my device manager, there are error messages and and the drives do not display when I check for it
  • 961 Answers
Go to device manager and click on the errors and see if they give you a recommendation. If not, right click on your device and you should see "disable" if you see "enable" click on that and exit. Right click on it again and click on "properties", then click on the driver tab. Click on "update driver", then click on "automatically search for..". Right click on device again and you should see "this device is working properly".
Posted on Mar 30, 2011
My husband recently built a new computer (previously built 5 others successfully). Motherboard seems to be working properly. Green LED lit. Graphics card works in another computer. Power supply...
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Apr 12, 2011 | ASUS M4N75TD AM3 NVIDIA nForce 750a SLI...
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
Unknown power supply
I think any up to date psu will work they are pretty much all the same except fo the really small pc's I would get a 400 watt one for your machine.
Aug 10, 2009 | Work Station 250W ATX POWER SUPPLY (=...
Installing a new power supply unit
Nothing to worry about, there are always extra connectors for different configurations.As long as you have the 24 pin and 4 pin connected to the MoBO and your CD/DVD drives and HDD are powered you'll be OK
Jul 30, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
CD rom not working
there is a problem in ur drive,go for a new one
Jan 31, 2009 | Dell Inspiron 5100 Notebook
Your new power supply for an HP Compaq D530 CMT
I have the 550 cooler master from Fry's electronics(outpost.com) and it fits my ATX just fine
Dec 29, 2008 | Computers & Internet
Asus K8V SE Deluxe - will not turn on
it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Dec 05, 2008 | ASUS K8V-MX Motherboard
Orange flashing lights
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Mar 18, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
OEM Systems Athenatech 400W ATX V2.01 Power Supply High Quality Excellent Performance Popular Modern Design (PS400WX1) 400-Watt Logo
52 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Terry Hair
Bill Boyd
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
