Question about Sony KDS55A2000 55" HDTV
Sony KDS-55A2000. bought 1/07. replaced bulb 2/08. gave tv to parents 11/10. worked fine until last week. 1 on screen message, temperature warning (they checked all vents-everything clear and 1' away from wall) then lamp going out message came across. red light blinked 4x and powered off. I ordered new lamp assy came in mail today. parents installed. green light came on then red light blinked 4x-nothing. parents don't have extra income and my financial help is limited. any easy fix solutions?????
    President:
  • 1,623 Answers
You will need to check the fans are all switching on when you turn the tv on, it might be one of the fan sensors that has gone bad, the tv wont turn on if it detects that the fans or a single fan is not working. I have not worked on this particular set , but that would be the first place i would look, if you find a fan is not firing up and if you have a multimeter, then check to see if you have a 12v voltage going to the fan, an easy way of rectifying it is to run a wire from one of the other working fans to the positive of the fan that isnt working. This would at least eliminate the fan as the culprit, if the tv starts up normally then the problem lies in why the fan is not receiving power. I ran a tv using this method for over 8 months before it died, from other problems i might add , not the fact i bypassed the fan power circuit.
If you found this info useful please take a moment to vote for me
Posted on Mar 31, 2011
How to get a picture on sony FULL HD 1080
Hi. Not shore of this model but could be a bulb replacement is needed, Or one of the filter covers may not be making contact.
The red light is indicative of error rather than working ( green ) or standby ( orange ).
I hope you get it sorted.
Sep 12, 2014 | Sony XL5200 LAMP - TV KDS-50A2000,...
Tip
Sony KDS-55A2000 Service Manual
Download Sony KDS-55A2000 HDTV Service Manual
Models: KDS-50A2000 / KDS-50A2010 / KDS-55A2000 / KDS-60A2000 / KDS-60A2010
Have you misplaced your Sony KDS-55A2000 HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Sony KDS-55A2000 HDTV Service Guide?
Follow this link (& click FREE) to download a pdf version of the Sony KDS-55A2000 HDTV Service documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Televison & Video
Tip
I hope that helps.
on May 08, 2010 | Sony KDS55A2000 55" HDTV
Hello, I have a Sony KDS-55A2000 and it works fine for a couple of minutes and then it switches off and the green led starts blinking for about a minute and then the picture comes back and works fine
First thought would be the lamp may be about to fail if it has not been replaced in a long time---a warning will be the picture is a bit darker than before and takes longer to get bright than it once did.
Apr 17, 2012 | Sony KDS55A2000 55" HDTV
I JUST REPLACE MY LAMP IN MY SONY KDS-55A2000 HOW DO I RESET THE LAMP HOURS..TV IS STILL READING PROJECTION LAMP NEARING LIFE END
you need to go into the TV's menu and select replace projection lamp menu and follow the on screen instructions to verify and reset the lamp timer, (its in your instruction manual , in detail) , i am awaiting a new phillips bulb for mine, as i always use the original enclosure, no need for extra plastic, and its easy to complete the swap, and reset hours via TV menu
Aug 03, 2010 | Sony KDS55A2000 55" HDTV
60in Sony KDS-60A2020 LCD rear projection picture goes on and off
yes replace the lamp, sony units have certain specs that the lamp must meet to operate correctly. If the Lamp you purchased is made by LTI, these lamps do not last long as they are poorly manufactured. Look at the bulb and see who is the maker if its says LTI then replace with a Phillips brand that meets spec's for sony.
Jan 30, 2010 | Sony KDS-60A2020 60" HDTV
I have a Sony KDS 55A TV.
Please check color temperature adjustment in menu and also check white balance adjustment.
Jul 23, 2009 | Sony KDS-55A2020 55" Television
Sony KDS-R50xBR1 Needs projection lamp replaced
I bought a True replacement from the PartsStore through Amazon.com and it cost me about $185, but it was a Phillips bulb and the full cartridge replacement. I went with the aftermarket bulb only replacement the first time, lasted less than a week and haven't resolved that issue yet.
Apr 06, 2009 | Sony KDS-R50XBR1 50" HDTV
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS55A2000 55" HDTV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
