Question about Rockford Fosgate Rfc2d 2 Farad Hybrid Digital Capacitor
Are the capacitors suppose to stay lit and will it kill my battery?
    New Friend:
    Problem Solver:
  • 10 Answers
It should be turned off with the key. If it continues to stay on it is installed incorrectly to a constant power source.
Posted on Jan 23, 2013
  • Chris Laughren Mar 14, 2015
    No. Buzzzzzzzzz!!!! Wrong. Cap is always hot. The positive is hooked up directly to the positive terminal of your battery, hence ALWAYS hot. Digital readout will come on when a drain is 'sensed' by the stiffening capacitor. Shoot me if wrong.
Security light stays on when car is locked with key flob or power door lock button kills battery but if you lock it manually light goes out,
The light is supposed to stay on, when the key is used the system is not armed, it should not kill the battery if the battery is in good shape. I suggest you take it and have the battery load tested.
Apr 28, 2016 | 2001 Cadillac DeVille
Clock display light won't turn off even with the unit off
Press and hold MODE and then press PRESET 1 to turn on or off the clock display priority. This should allow you to set if the clock stays on while the unit is off.
Aside from this, you may need to double check your wiring, specifically the RED and BLUE wires. The RED needs to be connected to a switched source of power and not directly to your battery/etc. It needs to be a source that is only ON when you want it to be ON (such as the ignition on wire). The YELLOW wire is the only one that should be connected directly to your battery.
Double check the BLUE wire is connected correctly to your AMP as the AMP running all the time would kill a car battery overnight where-as the stereo clock display alone should take many days to kill a properly functioning car battery.
Nov 11, 2017 | Dual XD-7500 CD Player
Have a 1990 525i and the window buttons stay lit when car is off and i think its draining the battery, is it normal for them to stay on?
Do not believe it should stay on. Does it stay on even after you open the door and remove the key? Does it ever go out? Let me know and I'll try and help
Feb 11, 2013 | 1990 BMW 5 Series
My left turn signal stays lit even when the car is turned off. I have to disconnect the battery so it does not kill it
Since the bulbs only get power when the turn signal switch is used, it sounds like your switch has a fault. and needs replacing.
Dec 13, 2012 | 2003 Volkswagen Passat
On my 94 jeep im having an electrical problem, something is killing my battery and i checked the alternator and my starter and i can not find the solution something is killing my battery rapidly please...
START THE VEHICLE, PUT A VOLTMETER ON THE BATTERY. THE VOLTAGE SHOULD READ 13.90 TO 14.80. IF THAT IS OK, THERE MAY BE A BATTERY DRAIN. TURN OFF EVERY SWITCH IN THE CAR.CLOSE ALL THE DOORS. MAKE SURE ALL THE COURTESY LIGHTS ARE GOING OUT. & THE GLOVE COMPARTMENT LIGHT. RAISE THE HOOD. DISABLE ANY UNDER HOOD LIGHTS. DISCONNECT THE NEG. CABLE FROM THE BATTERY. PUT A 12 VOLT TEST LIGHT, ONE END ON THE NEG BATTERY POST & THE OTHER END ON A GOOD GROUND { METAL }. IF THE LIGHT COMES ON THERE IS A BATTERY DRAIN. NO LIGHT , NO DRAIN. IF IT'S ON, ONE AT A TIME PULL THE FUSES OUT OF THE POWER DISTRIBUTION BOX. IF THE LIGHT STAYS LIT, PUT THE FUSE BACK. DO THIS WITH ALL THE FUSES BIG & SMALL. IF THE LIGHT STAYS LIT, DISCONNECT THE ALTERNATOR. THEY CAN CHARGE THE BATTERY WHILE RUNNING, & DRAIN WHEN STOPPED.
Jan 11, 2011 | 1994 Jeep Grand Cherokee
Is the light supposed to stay on? I just got started with a wireless keyboard and mouse and it looks like the laser light on the mouse stays lit all the time? Is that normal? How often will I have to...
Yes it is normal for the laser light to be on all the time.
And you will change your battery depending on its durability.
So when the mouse or keyboard stops working then you should know its time to change your battery.
I hope this solution has been helpful.
Sep 27, 2010 | Microsoft Wireless Laser Mouse 5000
2005 Lincoln Aviator
On my 2004 Aviator, the indicator was lit all the time, and it did kill the battery if I didn't drive it every day. The dealer stated it should only remain lit for 20 minutes, and replaced the shift assembly. Sounds like they shortened the illumination time to 10 minutes.
Mar 10, 2009 | 2005 Lincoln Aviator
Rockford Fosgate Rfc2d 2 Farad Hybrid Digital Capacitor Logo
144 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
