Question about Remote Start System
I have a 99 gmc yukon with a Viper auto start & alarm system. My car is turning over but won't start!!!
  • Viper Master
  • 625 Answers
The issue may be with the immobilizer bypass module. Is this a new installation? If not, did the remote starter work before?
Posted on Mar 30, 2011
Where is the fuse to the alarm for a 2003 gmc yukon
2003 GMC Yukon Car Security Wiring Diagram
www.modifiedlife.com/2003-gmc-yukon-car-security-wiring-diagram/
Whether your an expert GMC Yukon car alarm installer, GMC Yukon ... GMC Yukon, a 2003 GMC Yukon car alarm wiring diagram can save yourself a lot of time. .... Alex, double check ALL your fuses and make sure ALL your fuses are good.
How to Disable a Car Alarm - YouTube
? 2:41
https://www.youtube.com/watch?v=EKbjYlK4g0E
May 13, 2009 - Uploaded by ehowauto
In order to disable a car alarm, an individual will have to locate the horn that was put in and disconnect it, or ...
GMC out alarm fuse Questions & Answers - Fixya
www.fixya.com/tags/out_alarm_fuse/browse/gmc
If you have an alarm installed remove the in line fuse from the alarm and see if that ...Multiple issues with my 2003 GMC Yukon XL and hope someone can offer .
Jan 20, 2016 | GMC Cars & Trucks
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2004 yukon denali keeps cutting off with viper alarm
check all the connections to the viper/i cant count how many of them i have thrown over the hill
Feb 28, 2011 | GMC Yukon Denali Cars & Trucks
I have a viper 150 HF in a 1994 GMC truck. It will try to start but not turn the starter over, it does have the lights and buzzer sequence start.
I f you are trying to remote start the vehicle, what you will need to do is use a new relay that is rated for 40 amps. The problem you are having is that most remote start relays in alarms are only rated for 20 amp and the vehicle you are talking about uses close to 30 amps to start. Good Luck.
Feb 21, 2011 | Remote Start System
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Replaced starter on '99 Yukon. When reconnected
I can't say for sure but it sound like you either trigger the "Panic" button or alarm system if equiped. Hook the battery up (negative last) and push the "Panic" button on the key FOB.
If you don't have the FOB you may be able to reset but disconnecting the negative cable only.
If it's an alarm system, locking and then unlocking with the FOB should reset it, also using the key to turn on the ignition is supposed to reset it.
Jun 06, 2010 | 1999 GMC Yukon
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Remote Start System  Logo
583 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
