Question about Pioneer DEH-4300UB Car CD/ MP3 Player
What are the best settings for bass , treble and mid in order to get the best sound
    Problem Solver:
  • 3 Answers
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Posted on Mar 31, 2011
Raido bass setting after turning down resets itself back to a higher level
See if you can put the stereo in custom mode, it should be one of the sound/audio settings, then set the bass, mid, and treble the way you want it.
Mar 21, 2011 | 2006 Chevrolet Colorado
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
In most of the Amplifiers we have only Bass and Treble control (Bass works on 100 HZ and Treble works on 10KHz - approximately). In some Amplifiers we have Mid range control also. What is the frequency...
The frequency of mid range control is about 1KHz. The bass and treble are usually enough to set the tone of sounds and music, and if the customer has high quality speakers connected to the amplifier it is almost unnecessary to modify any tone. In my opinion you are right that x-band equalizer became less important now.
Thank you.
gylacz
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
Where are the bass,treble,mids,high on a basic EQ.I have an 12 band stereo eq.what #'s are the bass,etc.
Bass will be anything below 300Hz, mid will be 300Hz to 5KHz (Voice), above 5KHz will be Treble.
Nov 01, 2009 | Audio Players & Recorders
How do I set up the equalizer for a Honda CRV?
BETWEEN BASS AND TREBLE YOU WILL HAVE WHAT IS KNOWN AS MID RANGE, JUST PLAY WITH IT UNTIL IT IS WHAT YOU LIKE
May 04, 2009 | Car Audio & Video
I want to get the metallica sound from my marshall AVT50
Use the high gain channel. Set the bass to 8-10 set set the mids to 6-7 and the treble to taaste to cut through. Also turn the contour all the way up. To gice that scooped mid sound. Or use the celan channel on the amp and run a boss metal zone pedal through it. Set amps clean channel EQ to flat ( at 5) and the metal zones controls. Treble to taste for a good bite, bass up to the point were it wont fart out on your amp, sweep the mids outer knob set about 5-7 and the inner knob to about 4. Set prescence for clearity and the distortion level as high as you can stand it.
Aug 19, 2008 | Audio Players & Recorders
Bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Nov 08, 2007 | Audio Players & Recorders
Pioneer DEH-4300UB Car CD/ MP3 Player Logo
3,043 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
