TV has has lamp and thermal sensor replaced since purchased in 2006. Now the TV comes on then shuts off after about 30 seconds and the red light on the front panel stays on. It will not turn back on as long as the red light is on.
    Master:
  • 354 Answers
That is the problem with the new sets the bugs haven't been worked out . The analog sets last longer ,more reliable and have been debugged over decades of time. It sounds like another thermal sensor ,because what is happening is once it cools off you can turn it back on. Try and move it out from the wall or a place where air circulates around it,that should help, This time when the thermal sensor gets replaced tell the guy to put a heat sink on the component to keep it cool.
Posted on Mar 30, 2011
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
Nov 03, 2009 | Samsung HLR5064W DLP Projection TV
TV shuts off after 30 seconds.
Check chassis venting, sounds like thermal switch is tripping on top of light box.
Jun 25, 2009 | Samsung HLM507W 50" Rear Projection HDTV
Power shut down, why?
Part Number 80.95C06.001
you can get this part from www.encompassparts.com
also i recommend to replace the lamp too
Part Number928137805390 lamp W/out cage
Apr 12, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Jan 24, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
