Question about ASUS Computers & Internet
I am trying to run multiple operating systems, from two separate hard drives. I have 2 operating systems on my SATA Hard Drive and one on an IDE hard drive. I can not get both hard drives to come up on my boot order in bios. If either one is checked as hard drive number one, the other refuses to show.
  • 374 Answers
As you probably know, in a dual-boot setup where you have 2 OS's on one drive, you will get a menu at boot from which you can choose which OS you want to load. However even if your bios would allow you set HDD #2 as your 2nd boot device, the only way you could ever boot from that device would be if power was removed from HDD #1. (Perhaps one of your drives is an external drive?) Since you have an IDE/SATA configuration there may be a way to accmplish what you are trying to do - It will depend on the ASUS BIOS options.
I hate to pass the buck here, but I think that you will be able to get a prompt answer to your question by talking directly to ASAU Tech Support. I have 2 numbers for them. 812-282-2787 and 502-995-0883. Good luck...
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Posted on Mar 31, 2011
    Master:
  • 354 Answers
I am suspecting that you didn't change the jumpers on the back of the hard drive to master and slave ,but that is one of the things you have to do. Then your motherboard has to have the capacity to run a program called 'Raid' which is a multiple hard drive configuration which has five choices or methods for doing so,you might want to look into it a little further.
Posted on Mar 30, 2011
Hi. How to find files/Doc was format in HP Pavilion dv6
This kind of problem sometimes happens if the operating system files to start up on your laptop hard drive get corrupted. See if you can find instructions on youtube to take the hard drive out of your laptop, or see if there is a screw that holds it in your laptop. You will need to purchase a USB to IDE/SATA cable adapter to connect your laptop hard drive to another, working computer. Once the screw is out, and you remove the laptop hard drive, then plug one cable (IDE/SATA) into your hard drive, and the other end (USB) to the second computer that is working. You will also need to connect a power cable from your laptop hard drive to a separate power supply that comes in the USB to IDE/SATA cable kit. When the cables are connected, if your hard drive is usable, you should be able to see all the files from your laptop hard drive on the second computer. Now, you can copy them off before reinstalling your operating system/formatting your original laptop hard drive.
May 07, 2015 | HP Pavilion dv6-7010us Entertainment...
I hav forgett my usbcod
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Jun 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cant remember password to wd external hard drive
USB Memory Drives"
Hope this helps
May 25, 2011 | Western Digital My Book Essential 1TB...
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Using a Sata Drive with an IDE cable
Depending on how old your system is, even though your current drive is IDE, there might still be SATA support on the motherboard. Look in your manual and find out if it has any SATA connectors. If not, you need to continue using IDE unless you want to purchase a PCI card with SATA connectors on it.
Apr 28, 2008 | Computers & Internet
Sata and IDE hard drive
hi there,
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Apr 27, 2008 | ASUS P4S8X Motherboard
Sata , ide
Initially connect only the sata drive from which you want to boot the OS. Establish the OS successful operation from this drive. Then connect the remaining drives in conventional way or the RAID array you want to have.
Oct 25, 2007 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
