Question about KitchenAid Dryers
Model number keyw777bwh2 tub doesn 't turn in dryer
Clothes are melting in my dryer
Hello Thelma;
My name is Peter. I am a retired field service appliance technician.
Good for you changing the fuse. More and more women are becoming handy with repairs.
Unfortunately, the fuse blew because of another problem.
You may have a high temperature limit switch problem. You may have a time cycle problem.
This is a hard question to answer since you did not provide a model number for me to see what dryer you have.
Please submit your question with the model number. Open the dryer door the model number is on a label inside the door.
Nov 30, 2014 | Kenmore Dryers
Whirlpool dryer awz123 make loud noise
sounds like a bad tub wheel that the drum rides on ,just take the front off look in the back ,there are two wheels that the tub rides on ,go to your Sears parts dept with the model number ,get the part easy job
Jan 15, 2013 | Dryers
I need a picture of the control board for a ge adora dryer
You have to program you new board. I think you enter into the t01 mode and then select the number that corresponds to your model dryer. Here is a link for the manual that shows steps to replacing the control board.
http://www.applianceblog.com/manuals/31-9136_GEFDryer.pdf
Dec 05, 2012 | Dryers
Dryer runs but no heat and doesn't turn off
What is the complete model number of the unit?
Nov 07, 2012 | Dryers
Dryer
You need to check the belt around the outside of the tub that turns the tub, the tention pully and the motor. is the belt broke? loose? motor turning?
Aug 17, 2012 | Dryers
I have a Frigidaire Stacker washer dryer that has no model number anywhere and a tub seal with numbers that I have been unable to cross reference.
John, check out http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=1084015&ModelNum=FEX831CS0&mfgModelNum=&ManufactureID=4&Selected=OMQBC08N&Position=5&mfg=Frigidaire&Type=&Mark=5r
Jun 02, 2012 | Frigidaire FEX831CS Top Load Stacked...
Tub is not rotating but the belt is intact,it is an older model but dont know the model number
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 24, 2010 | Maytag Dryers
Frigidaire dryer - tub will not tumble/turn....what to do? Can read all of the model numbers....the label has a crease it in.
If the machine sounds like it is running but the drum is not turning then you most likely have a broken or unseated belt. Just open up the top of the dryer and have a look at the belt on the rear of the drum usually. Most appliance parts stores should carry belts but you would need the model number to know which belt you need. See if you can find the manual for the machine. Otherwise you'll need to have a pro come and figure out your model number.
Dec 13, 2009 | Frigidaire Electric Dryer
Dryers Logo
27 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
