Question about Vacuums
How to replace bulb. - Vacuums
  • Handie Andie
    Handie Andie Mar 30, 2011
    What make and model vacuum do you have?
    Handie Andie
    Problem Solver:
  • 10 Answers
I think the first power off and then put the lamp down, and put new on the line
pandora charms
Posted on Mar 31, 2011
Replace dome light bulb in 2004 f150 truck
Your dome light has three different bulbs inside of it. Two of the bulbs are reading lights which is part number 912. The bulb mounted in the center is part number 578. LED versions are available but are still pricy. They would cost around $75.00 verses the $10.00 it would cost to buy the other style. Good luck.
Jan 15, 2014 | Reliable C8SBH Sleeve Board and Bottle...
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
Replacement bulb for S1720 Ionic Breeze GP
You need a G6T5 bulb.
Here is one of many online sources for this bulb:
http://www.replacementlightbulbs.com/lampg6t5.html
Good luck.
Mar 02, 2011 | Vacuums
I took the bulb out but I can not get the new one in! it is as if the holes are closed
What brand is your vacuum? I have a Kirby with the light in the front. Make sure you have the correct bulb with the same size and number of threads. Look on the web under repair instructions for you particular brand and see if there is a description for replacement of the bulb. If you have a vacuum cleaner parts and repair store at your location, then you should call them. Something as simple as changing a bulb on your specific should not present a problem for them. I do not follow what you mean by the holes seem to be closed. Is it that the bulb will not go in the hole for some reason or that you cant install it? Have you tried to see if the old bulb will go back in the hole you removed it from. If it does, then you have the wrong replacement bulb. If it doesnt, then there must be some leaver or somehting you have to engage or disengage to get the hole to open. Of course, make sure the machine is unplugged while you are doing any of these functions.
Feb 03, 2011 | Vacuums
My Hoover Soft and Light Supreme upright vacuum has a model #U4264-930. The last two numbers in serial # are 05. I have no manual and need to change a burned out light bulb. Need to know two things:...
http://www.vacshopusa.com/pdf/hu4253930.pdf Use this link to download a pdfd scehmatic for your model. This link is the site I got it from. http://www.vacshopusa.com/elite_%26_elite_ii.htm You may find more info there. Just from looking at the schematic, I would guess the bulb cover would pop off (carefully) and see what type of bulb it is. Remove it, take it with you to buy a replacement.
Nov 21, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Light bulb burning out.
My guess is you didnt get the correct value lamp for your application. Sears doesnt have the proper lamp for your machine - of you didnt want to get it from them?
Try again at Sears or RepairClinic.com for the proper lamp.
I hope this helps you
a
Oct 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
May 11, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
