Question about PANDIGITAL Novel eReader
I just tried to turn on my Pandigital Ereader and the screen has gone almost completely black. There are some lines, but nothing is happening. I held the power switch for more than 5 seconds, but nothing else happened. Is there a way to reset the reader, or to do something to fix the screen?
  • orientalspud Mar 31, 2011
    I wasn't able to follow the factory reset directions in the manual because I can't see anything on the screen. I don't even know if the device is turning on. It was fully charged before I tried to use it. I just held the power switch for 30 seconds (on the clock) and nothing happened then either.
  • 6,993 Answers
there are three things involved;
Its either the unit is not turning on, or its turned on and the screen is defective or the unit is corrupt.
First, check the battery to make sure is powering on the unit.
But if it is not a screen and battery problem, then it is possible that the OS of your unit is corrupt.
Just make sure you figure out first, what wrong with the unit, then a solution can be proffered.
Bye for now.
Posted on Mar 31, 2011
  • 12,061 Answers
Http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
OK above is your user guide, have a look in there and follow the directions for the "Factory Reset" this should reset your device back to exactly how you received it from the factory, you will have to re-set up/configure all software settings again however.
Often you may simply need to hold the button down for about 20 - 30 sec's ON THE CLOCK.... this too will "Reset" the unit.
but have a look through your guide, all answers are inside, & I am sure it will help.
Posted on Mar 30, 2011
How to register
try Pandigital.com not .net
Jun 10, 2015 | PANDIGITAL Novel eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Unknown server error on pandigital ereader
I have had that twice and both times had a different fix. 1) access your B&N account thru the ereader and completely delete your credit card info, and then readd-I had a tech support tell me that and it worked! 2) Make sure the time is correct. If it doesn't match B&Ns time within a couple minutes, you'll get that error mssg. Hope this helps!
Jun 26, 2013 | PANDIGITAL Tablets & eReaders
My tablet wont turn on passed the blue start screen
Take the battery out of it for1 minute then re-install it and turn it on.
Aug 22, 2012 | PANDIGITAL Novel eReader
My granddaughter ordered a book from Barnes and Noble for her Pangital e-reader. Only half the book came over the lines. Could you help us. B&N said that we need to contact Pandigital
You need to demand B&N let you download the whole thing again for free, there is nothing pandigital could possibly do about it. Also you might want to thank them for giving you the run-around as well. Be assertive, it's all on B&N.
Jun 29, 2012 | PANDIGITAL Novel eReader
My pandigital novel ereader froze how do I reset it
Unplug for about ten seconds and plug back on!!!generally electronics will reset themselves....good luck!!
Jun 20, 2012 | PANDIGITAL Novel eReader
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Pandigital novel 7" WHITE ereader wont turn on.
You can try pressing the reset button with a straightened paperclip of pin. If that doesn't do anything removing the back and unplug the battery. Leave it unplugged for a minute or two and reconnect it. Be careful unplugging it as you don't want to put to much force on the wires. You can use a small screw driver or tweezers to pry on the plug. The white plug here is what you're locking for. See if it powers on and hopefully it does. If not you may have to contact Pandigital.
Hope this helps
Ray
Mar 12, 2011 | PANDIGITAL Digital Book 843967071153...
PANDIGITAL Novel eReader Logo
688 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
brian soufane
rey francis basa
rey francis basa
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
