Question about Kyocera Switchback KX21 Cellular Phone
The screen went out
Both of my screens are black and sometimes the outside one is fine untill i open it and then there black again now both of them are stuck on black it used to fix itself when i would turn it off then on a couple of times
  • Anonymous Oct 17, 2008
    both screens blank
  • Anonymous Oct 29, 2008
    my phone works its just all black on the outside and inside. help!!!
I've got the same problem. If it turn it off one and sometimes both of the screens work, but usually only for a little while. then it starts spazzing out, or just going black.
Posted on Nov 23, 2008
Get ride of it
Posted on Nov 04, 2008
  • Kyocera Master
  • 13,433 Answers
Best to take it to repair, got warranty? contact your dealer or kyocera directly.
Posted on Aug 04, 2008
  • Ekse Aug 04, 2008
    Kyocera Contact Information
    Main support number 800-349-4188
    number may be out of date.
Toshiba Qosmio F25-AV205 screen keeps going black
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 14, 2011 | Computers & Internet
I don't kno whats wrong with it it was working fine last night. I was using it then the screen went black. Its turn on still but theres no regualr start up or safe mode boot just a black screen.
Can mean alot of things but try removing the battery & and the ram, leave it for sometime and place it back in the system. try run it again.
if not working, try this, remove the Hard drive and boot the laptop without the hard drive or disk. sometimes hard disk causes the system not to display anything on the screen when you switch on.
then you have to get a new hard drive to reinstall the system again.
Aug 19, 2010 | Computers & Internet
My motorola v557 cell phone doesn't light up. how
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 12, 2010 | Motorola Mobility V557 Cellular Phone
My lg chocolate touch's screen went half black
your screen has broken and LCD also has broken that's why your half screen is working and half is black. you have to change your screen and then use your phone again like before
May 17, 2017 | LG Cell Phones
Kyocera strobe
sorry to say but you have to replace the screen as the cable that goes from the screen to the phone through the hinge has broke.so when you have it half open its making contact.
Dec 26, 2008 | Kyocera K312 Cellular Phone
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
Hitachi model no 50es1k---july 1993
loose connection on circuit board and also maybe bad caps in vertical area.
Mar 03, 2008 | Televison & Video
Freezing then blank screen
you have a loose connection, good luck....
Jan 08, 2008 | Samsung X15 Notebook
Kyocera Switchback KX21 Cellular Phone Logo
82 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
