Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag model MDE5500AYW. lights on, door switch, timer all working, replaced thermistor. Start, signal up or down not working and lights are out. Will not start.
  • Maytag Master
  • 3,053 Answers
Hello, kend I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Maytag Neptune model MLE2000AYW. Why does it keep shutting down?
SORRY BUT UR QUESTION IS CONFUSING? U SAY IT SHUTS DOWNS THEN U SAY IT DOES NOT AGITATE? IF NO AGITATION I WOULD CHECK THE WATER PRESSURE SWITCH. UR DOOR SWITCH IS NOT LIKELY TO GO OFF AND ON, WHEN IT GOES BAD IT STOPS WORKING ALL TOGETHER. LESS U HAVE A BAD ACTUATOR? U CAN CHECK IT WITH A METER TO VERIFY , SEE PICS
AS FOR UR TIMER DOES IT ADVANCE ON ITS OWN? OR STICKING AND STOPPING AT A CERTAIN CYCLE?
May 27, 2015 | Maytag Washing Machines
Why won't my maytag neptune dryer start?
circuit breaker timer control board door switch . to name a few posabilities I would call a service man
Mar 15, 2015 | Maytag Dryers
Dryer will not start
Check to see if the door switch is working. If you have an interior light, it should go on and off when you press it. Post back your results.
Nov 20, 2012 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
No heat
Check for the wire inside the unit, maybe it's broken or cut off, replace or join it again will solve the problem
Oct 17, 2009 | Maytag Dryers
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
35 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
